2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Fix for building 3.15.4 on windows-x64-static
To: "'EPICS core-talk'" <[email protected]>
Date: Thu, 8 Sep 2016 09:09:20 +0200
Hi Mark,
On 08/09/2016 01:08, Mark Rivers wrote:
I have come up with a better solution for the problem with the Visual Studio 2010 compiler crashes.
I changed configure/os/CONFIG_SITE.Common.windows-x64-static as follows:
# 64-bit Visual Studio 2010 builds fail when built with the -GL optimization
# flag which is set in CONFIG.win32-x86.win32-x86 with these lines:
# OPT_CFLAGS_YES = -Ox -GL -Oy-
# OPT_CXXFLAGS_YES = -Ox -GL -Oy-
# The lines below have the -GL flag removed from OPT_CFLAGS_YES and OPT_CXXFLAGS_YES.
# If you are using a newer version of Visual Studio you can try removing these lines.
OPT_CFLAGS_YES   = -Ox -Oy-
OPT_CXXFLAGS_YES = -Ox -Oy-
My impression is that VS 2013 and 2015 do not have that issue. (For older versions, I only have access to the Express editions that do not contain 64bit compilers.)
Is there a way to determine the VS version during make, so that we could apply your suggested change only for specific VS versions that need it?
Cheers,
~Ralph
RE: Fix for building 3.15.4 on windows-x64-static Mark Rivers
Prev: RE: Fix for building 3.15.4 on windows-x64-static Mark Rivers
Next: RE: Fix for building 3.15.4 on windows-x64-static Mark Rivers
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 08 Sep 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
