Hi Freddie,
On 12/07/2016 05:22 PM, [email protected] wrote:
> I've added a couple of local mods we have to a PR against my GitHub
> fork of epics base which I wonder if you might consider for the
> official epics base release
> https://github.com/FreddieAkeroyd/epics-base/pull/1
> * one is just a simple buffer too small fix (which did actually cause
> me a crash when I mistyped something in a gateway access security
> file)
Fixed — I actually bumped it to 40 characters. That change will be in
the final Base-3.14.12.6 and Base-3.15.5 releases next week.
> * I find it very useful to always build and install pdb files on
> windows, and include rules for this. At the moment the install
> decision is based on an INSTALL_PDB macro
> * (I've also generated some additional /NODEFAULTLIB flags that I
> found useful, but they may a bit risky to deploy without more
> widespread testing)
We support cross-building Windows applications on Linux using MinGW, and
I'm not sure how some of your changes might affect that build
configuration, since GCC doesn't generate .pdb files. I think we're a
bit too close to the release to merge these more intrusive changes,
although I'm not rejecting them out-right. As I don't often develop on
Windows I don't know much about pdb files; if they're useful I don't
object to building and installing them, but would it make sense to have
them be optional?
I do have a few specific questions/comments:
1. What are the build-time implications of creating pdb files? I'm fine
with creating them when HOST_OPT=NO, which is meant to be the debug
configuration, but I'm not quite so convinced about doing that when
HOST_OPT=YES if they're going to slow down the compile/link steps.
2. Your STATIC_LDFLAGS_EXTRA_YES/NO variables can be named just
STATIC_LDFLAGS_YES/NO instead; the win32 config file is overriding a
setting in CONFIG_COMMON that already chooses between those two based on
the value of HOST_OPT.
3. I need to think a bit about your RULES_BUILD changes. I would prefer
to keep the install rules generic if possible, so I'll see if I can work
out an alternative approach which doesn't require adding .exe rules.
4. The name of your switch INSTALL_PDB is perilously close to the usage
in RULES_FILE_TYPE so I'll probably want to modify that name to call it
something else (it might make sense to use it to enable the -Zi flags
too, so something like ENABLE_PDB may be a better choice).
- Andrew
- RE: EPICS base mods freddie.akeroyd
Jenkins build is back to normal : epics-base-3.14-vx69 #172 APS Jenkins
<2016>
2025
2026
Jenkins build is back to normal : epics-base-3.14-rtems #173 APS Jenkins
<2016>
2025
2026
