2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: fedora 25: epicsExceptionTest.cpp does not compile
To: "'EPICS core-talk'" <[email protected]>
Date: Thu, 12 Jan 2017 06:22:40 -0500
I upgraded from fedora 23 to fedora25.
epics base builds except for src/libCom/test/epicsExceptionTest.cpp
It causes the following compiler error:
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -c ../epicsExceptionTest.cpp
../epicsExceptionTest.cpp: In function ‘void epicsExceptionTestPrivate()’:
../epicsExceptionTest.cpp:61:49: error: size of array is too large
         char * p = new char [unsuccessfulNewSize];
../epicsExceptionTest.cpp:74:38: error: size of array is too large
../../../../configure/RULES_BUILD:228: recipe for target 'epicsExceptionTest.o' failed
This happens on both  base-3.14.12.5 and base-3.16.0.1.
That test does not appear in base-3.15.5
Note that
mrk> g++ --version
g++ (GCC) 6.3.1 20161221 (Red Hat 6.3.1-1)
Copyright (C) 2016 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
The code that causes the error is:
static void epicsExceptionTestPrivate ()
    try {
        testFail("new char[%lu] returned %p",
            (unsigned long) unsuccessfulNewSize, p);
    catch ( const bad_alloc & ) {
        testPass("new char[%lu] threw",
            (unsigned long) unsuccessfulNewSize);
    catch ( ... ) {
        testFail("new: threw wrong type");
    try {
        char * p = new ( nothrow )
        testOk(p == 0, "new (nothrow) returned %p", p);
    catch( ... ) {
        testFail("new (nothrow): threw");
In particular the statements:
and
It appears that the compiler now detects the problem instead of the problem being detected at run time.
I commented out the code (thus test does not detect anything) and base builds without error.
Re: fedora 25: epicsExceptionTest.cpp does not compile Marty Kraimer
Prev: procServ 2.7.0-rc1 released Ralph Lange
Next: Re: fedora 25: epicsExceptionTest.cpp does not compile Marty Kraimer
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: procServ 2.7.0-rc1 released Mark Rivers
