2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: dllPath.bat problem
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 16 Jan 2017 16:17:11 -0600
Hi Mark,
OK, I just merged my fix from 3.14 up to the Base-3.15 branch. A few
other white-space changes (removal of trailing spaces) were also added
by the Atom editor that I'm currently trying out.
- Andrew
On 01/16/2017 03:58 PM, Mark Rivers wrote:
> Hi Andrew,
>> I will commit this change to Base (3.14 version)
> Thanks, I saw your commit on the 3.14 branch.
> I am actually running 3.15.5 now, so I needed a fix for 3.15.  This is what I did locally on my system:
> corvette:base-3.15.5/src/tools>
> diff -U3 convertRelease.pl.orig convertRelease.pl
> --- convertRelease.pl.orig      2017-01-16 13:58:35.650816372 -0600
> +++ convertRelease.pl   2017-01-16 14:01:21.853482937 -0600
> @@ -119,15 +119,15 @@
>      unlink $outfile;
>      open(OUT, ">$outfile") or die "$! creating $outfile";
>      print OUT "\@ECHO OFF\n";
> -    print OUT "PATH \%PATH\%;", join(';', binDirs()), "\n";
> +    print OUT "PATH ", join(';', binDirs()), ";\%PATH\%\n";
>      close OUT;
>  sub relPaths {
>      unlink $outfile;
> -    print OUT "export PATH=\$PATH:",
> -        join(':', map {m/\s/ ? "\"$_\"" : $_ } binDirs()), "\n";
> +    print OUT "export PATH=",
> +        join(':', map {m/\s/ ? "\"$_\"" : $_ } binDirs()), ":\$PATH\n";
>      close OUT;
> It seems to work for dllPath.bat.  I have not tested relPaths.sh.
> Mark
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf Of Andrew Johnson
> Sent: Monday, January 16, 2017 10:35 AM
> To: [email protected]
> Hi Mark,
> On 01/14/2017 05:14 PM, Mark Rivers wrote:
>> The EPICS build system can construct a dllPath.bat file in an ioc boot
>> directory.  This is very convenient when running IOCs built dynamically
>> for Windows.  An example of such a file is the one built in
>> asyn/iocBoot/iocTest.
>> corvette:asyn/iocBoot/ioctest>more dllPath.bat
>> @ECHO OFF
>> PATH
>> %PATH%;/home/epics/support/asyn-4-31/bin/linux-x86_64;/corvette/home/epics/support/seq-2-2-4/bin/linux-x86_64;/corvette/usr/local/epics/base-3.15.5/bin/linux-x86_64
>> However, I think there is an issue with these files.  Note that it puts
>> the current PATH at the beginning of the new path, rather than at the
>> end.  This means that if the current path contains a DLL with the same
>> name as a DLL created by EPICS, it will use the one in the current path,
>> not the one that EPICS created.  It seems to me that this is the wrong
>> thing to do, for several reasons:
>> -          What if the current path happens to contain, for example, a
>> DLL called "com.dll" or "ca.dll" which is completely unrelated to
>> EPICS.  It will use the wrong DLL.
>> -          What if the current path contains an older version of one of
>> the DLLs that EPICS built.  This is what just happened to me.  I have
>> the Anaconda Python bin/ directory in my path, and it contains
>> hdf5.dll.  It is an older version of the HDF5 library.  EPICS
>> areaDetector builds hdf5.dll using the latest code, actually patched
>> beyond anything the HDF5 group had yet released.  My IOC won't run,
>> because the old DLL does not contain the symbols added recently.
>> Are there any circumstances under which the current behavior would be
>> desired?
> Good point, I agree that for the reasons you describe the current output
> is wrong.
> An equivalent fix is also required for the relPaths.sh script, which is
> the Cygwin equivalent of the dllPath.bat file for those running IOCs
> under Cygwin and bash.
> I will commit this change to Base (3.14 version):
>> === modified file 'src/tools/convertRelease.pl'
>> --- src/tools/convertRelease.pl 2016-07-07 21:43:29 +0000
>> +++ src/tools/convertRelease.pl 2017-01-16 16:22:42 +0000
>>      unlink $outfile;
>> +    print OUT "PATH ", join(';', binDirs(), '%PATH%'), "\n";
>>      close OUT;
>>  sub relPaths {
>>      unlink $outfile;
>> +        join(':', map {m/\s/ ? "\"$_\"" : $_ } binDirs(), '$PATH'), "\n";
>>      close OUT;
> - Andrew
RE: dllPath.bat problem freddie.akeroyd
dllPath.bat problem Mark Rivers
Re: dllPath.bat problem Andrew Johnson
RE: dllPath.bat problem Mark Rivers
Prev: RE: dllPath.bat problem Mark Rivers
Next: Build failed in Jenkins: epics-base-3.15-mac-test #107 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: dllPath.bat problem freddie.akeroyd
