2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: dllPath.bat problem
To: <[email protected]>, <[email protected]>, <[email protected]>
Date: Tue, 24 Jan 2017 17:02:29 +0000
As you were talking DLL paths there is another minor change that might we worth doing too. If some application on your computer has decided to install itself in a directory containing an & character and then place this location in your PATH, you will get strange behaviour if you just try and add to the PATH in the way dllPath.bat currently does as & is a command separator - this results in the part of the PATH after the & being discarded. For example:
    set "PATH=A & B;C"
    PATH C;%PATH%
Prints      'B' is not recognized as an internal or external command, operable program or batch file.
and PATH is left containing just C;A
The solution is to quote the entire expression using the syntax       SET  "PATH=epicsdir1;epicsdir2;%PATH%"        in dllPath.bat
Freddie
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Andrew Johnson
Sent: 16 January 2017 22:17
To: Mark Rivers; [email protected]
Subject: Re: dllPath.bat problem
Hi Mark,
OK, I just merged my fix from 3.14 up to the Base-3.15 branch. A few other white-space changes (removal of trailing spaces) were also added by the Atom editor that I'm currently trying out.
- Andrew
On 01/16/2017 03:58 PM, Mark Rivers wrote:
> Hi Andrew,
>> I will commit this change to Base (3.14 version)
> Thanks, I saw your commit on the 3.14 branch.
> I am actually running 3.15.5 now, so I needed a fix for 3.15.  This is what I did locally on my system:
> corvette:base-3.15.5/src/tools>
> diff -U3 convertRelease.pl.orig convertRelease.pl
> --- convertRelease.pl.orig      2017-01-16 13:58:35.650816372 -0600
> +++ convertRelease.pl   2017-01-16 14:01:21.853482937 -0600
> @@ -119,15 +119,15 @@
>      unlink $outfile;
>      open(OUT, ">$outfile") or die "$! creating $outfile";
>      print OUT "\@ECHO OFF\n";
> -    print OUT "PATH \%PATH\%;", join(';', binDirs()), "\n";
> +    print OUT "PATH ", join(';', binDirs()), ";\%PATH\%\n";
>      close OUT;
>  sub relPaths {
>      unlink $outfile;
> -    print OUT "export PATH=\$PATH:",
> -        join(':', map {m/\s/ ? "\"$_\"" : $_ } binDirs()), "\n";
> +    print OUT "export PATH=",
> +        join(':', map {m/\s/ ? "\"$_\"" : $_ } binDirs()),
> + ":\$PATH\n";
>      close OUT;
> It seems to work for dllPath.bat.  I have not tested relPaths.sh.
> Mark
> Sent: Monday, January 16, 2017 10:35 AM
> To: [email protected]
> Hi Mark,
> On 01/14/2017 05:14 PM, Mark Rivers wrote:
>> The EPICS build system can construct a dllPath.bat file in an ioc
>> boot directory.  This is very convenient when running IOCs built
>> dynamically for Windows.  An example of such a file is the one built
>> in asyn/iocBoot/iocTest.
>> corvette:asyn/iocBoot/ioctest>more dllPath.bat @ECHO OFF PATH
>> %PATH%;/home/epics/support/asyn-4-31/bin/linux-x86_64;/corvette/home/
>> epics/support/seq-2-2-4/bin/linux-x86_64;/corvette/usr/local/epics/ba
>> se-3.15.5/bin/linux-x86_64
>> However, I think there is an issue with these files.  Note that it
>> puts the current PATH at the beginning of the new path, rather than
>> at the end.  This means that if the current path contains a DLL with
>> the same name as a DLL created by EPICS, it will use the one in the
>> current path, not the one that EPICS created.  It seems to me that
>> this is the wrong thing to do, for several reasons:
>> -          What if the current path happens to contain, for example, a
>> DLL called "com.dll" or "ca.dll" which is completely unrelated to
>> EPICS.  It will use the wrong DLL.
>> -          What if the current path contains an older version of one of
>> the DLLs that EPICS built.  This is what just happened to me.  I have
>> the Anaconda Python bin/ directory in my path, and it contains
>> hdf5.dll.  It is an older version of the HDF5 library.  EPICS
>> areaDetector builds hdf5.dll using the latest code, actually patched
>> beyond anything the HDF5 group had yet released.  My IOC won't run,
>> because the old DLL does not contain the symbols added recently.
>> Are there any circumstances under which the current behavior would be
>> desired?
> Good point, I agree that for the reasons you describe the current
> output is wrong.
> An equivalent fix is also required for the relPaths.sh script, which
> is the Cygwin equivalent of the dllPath.bat file for those running
> IOCs under Cygwin and bash.
> I will commit this change to Base (3.14 version):
>> === modified file 'src/tools/convertRelease.pl'
>> --- src/tools/convertRelease.pl 2016-07-07 21:43:29 +0000
>> +++ src/tools/convertRelease.pl 2017-01-16 16:22:42 +0000
>>      unlink $outfile;
>> +    print OUT "PATH ", join(';', binDirs(), '%PATH%'), "\n";
>>      close OUT;
>>  sub relPaths {
>>      unlink $outfile;
>> +        join(':', map {m/\s/ ? "\"$_\"" : $_ } binDirs(), '$PATH'),
>> + "\n";
>>      close OUT;
> - Andrew
Arguing for surveillance because you have nothing to hide is no different than making the claim, "I don't care about freedom of speech because I have nothing to say." -- Edward Snowdon
Re: dllPath.bat problem Andrew Johnson
dllPath.bat problem Mark Rivers
RE: dllPath.bat problem Mark Rivers
Prev: Jenkins build is back to normal : epics-base-3.15-mac-test #108 APS Jenkins
Next: Re: dllPath.bat problem Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: dllPath.bat problem Andrew Johnson
