2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: dllPath.bat problem
To: <[email protected]>, <[email protected]>
Date: Tue, 24 Jan 2017 11:44:20 -0600
Hi Freddie,
On 01/24/2017 11:02 AM, [email protected] wrote:
>     set "PATH=A & B;C"
>     PATH C;%PATH%
> Prints
>      'B' is not recognized as an internal or external command,
>      operable program or batch file.
> and PATH is left containing just C;A
> The solution is to quote the entire expression using the syntax
>       SET  "PATH=epicsdir1;epicsdir2;%PATH%"
> in dllPath.bat
Presumably
    PATH "epicsdir1;epicsdir2;%PATH%"
will also work (seems to be OK for me), i.e. I just need to add quotes
around the whole generated argument.
I prefer using the slightly shorter PATH command, which also makes it
easier for a human to see at first glance that it's adjusting the PATH
instead of setting some other variable whose name just begins with PATH.
Done — thanks,
- Andrew
RE: dllPath.bat problem freddie.akeroyd
dllPath.bat problem Mark Rivers
Re: dllPath.bat problem Andrew Johnson
RE: dllPath.bat problem Mark Rivers
Prev: RE: dllPath.bat problem freddie.akeroyd
Next: RE: dllPath.bat problem freddie.akeroyd
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
