2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: dllPath.bat problem
To: <[email protected]>, <[email protected]>
Date: Tue, 24 Jan 2017 19:22:53 +0000
Hi Andrew,
> Presumably
>    PATH "epicsdir1;epicsdir2;%PATH%"
> will also work (seems to be OK for me), i.e. I just need to add quotes around the whole generated argument.
Unfortunately this syntax embeds the quotes in the PATH
Set "PATH=a;b"           -> PATH is   a;b
PATH "c;%PATH%"    ->  PATH now contains   "c;a;b"    rather than    c;a;b
PATH "c;%PATH%"    ->  PATH now contains   "c;"c;a;b""
And multiple additions to the PATH will fail if the original PATH contained an &
Set "PATH=a;b & c"
PATH "c;%PATH%"  -> no error printed, path contains "c;a;b & c"
PATH "c;%PATH%"
Now prints     'c""' is not recognized as an internal or external command, operable program or batch file.
And PATH is left containing   "c;"c;a;b
I agree the shorter PATH syntax looks nicer, but it may be safer to go with the longer syntax
Freddie
-----Original Message-----
Sent: 24 January 2017 17:44
To: Akeroyd, Freddie (STFC,RAL,ISIS); [email protected]
Subject: Re: dllPath.bat problem
Hi Freddie,
On 01/24/2017 11:02 AM, [email protected] wrote:
>     set "PATH=A & B;C"
>     PATH C;%PATH%
> Prints
>      'B' is not recognized as an internal or external command,
> and PATH is left containing just C;A
> The solution is to quote the entire expression using the syntax
>       SET  "PATH=epicsdir1;epicsdir2;%PATH%"
> in dllPath.bat
Presumably
I prefer using the slightly shorter PATH command, which also makes it easier for a human to see at first glance that it's adjusting the PATH instead of setting some other variable whose name just begins with PATH.
Done - thanks,
- Andrew
Arguing for surveillance because you have nothing to hide is no different than making the claim, "I don't care about freedom of speech because I have nothing to say." -- Edward Snowdon
Re: dllPath.bat problem Andrew Johnson
dllPath.bat problem Mark Rivers
RE: dllPath.bat problem Mark Rivers
RE: dllPath.bat problem freddie.akeroyd
Prev: Re: dllPath.bat problem Andrew Johnson
Next: Re: dllPath.bat problem Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
