2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: dllPath.bat problem
To: <[email protected]>, <[email protected]>
Date: Tue, 24 Jan 2017 14:16:43 -0600
On 01/24/2017 01:22 PM, [email protected] wrote:
> Hi Andrew,
>> Presumably
>>    PATH "epicsdir1;epicsdir2;%PATH%"
>> will also work (seems to be OK for me), i.e. I just need to add
>> quotes around the whole generated argument.
> Unfortunately this syntax embeds the quotes in the PATH
Wow! That ... they ... <censored> ... :speechless-emoji: !
Ok, fixed properly now to use your syntax, thanks!
- Andrew
dllPath.bat problem Mark Rivers
Re: dllPath.bat problem Andrew Johnson
RE: dllPath.bat problem Mark Rivers
RE: dllPath.bat problem freddie.akeroyd
Prev: RE: dllPath.bat problem freddie.akeroyd
Next: Build failed in Jenkins: epics-base-3.15-win32-test #99 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: CA server bind failure on Windows Andrew Johnson
