2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.14-win32s #182
To: [email protected]
Date: Mon, 3 Apr 2017 17:29:56 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.14-win32s/182/display/redirect>
Started by upstream project "epics-base-3.14-win32" build number 187
originally caused by:
 Started by upstream project "epics-base-3.14" build number 238
  Started by user Andrew Johnson
[EnvInject] - Loading node environment variables.
Building remotely on win32-1 (win32) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.14-win32s/ws/>
[epics-base-3.14-win32] $ cmd /c call C:\Users\jenkins\hudson7891720988664096375.bat
<https://jenkins.aps.anl.gov/job/epics-base-3.14-win32s/ws/>make> -O -j4 EPICS_HOST_ARCH=win32-x86-static
'make' is not recognized as an internal or external command,
operable program or batch file.
<https://jenkins.aps.anl.gov/job/epics-base-3.14-win32s/ws/>make> tapfiles EPICS_HOST_ARCH=win32-x86-static
<https://jenkins.aps.anl.gov/job/epics-base-3.14-win32s/ws/>exit> 9009
Build step 'Execute Windows batch command' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.win32-x86-static/*.tap
Did not find any matching files.
[WARNINGS] Skipping publisher since build result is FAILURE
Build failed in Jenkins: epics-base-3.14-win32s #183 APS Jenkins
Jenkins build is still unstable: epics-base-3.14-win32s #181 APS Jenkins
Prev: Build failed in Jenkins: epics-base-3.14-win64s #185 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.14-win32 #188 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is still unstable: epics-base-3.14-win32s #181 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.14-win32s #183 APS Jenkins
