2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.14-win32s #183
To: [email protected]
Date: Mon, 3 Apr 2017 17:44:10 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.14-win32s/183/display/redirect>
Started by upstream project "epics-base-3.14-win32" build number 188
originally caused by:
 Started by user Andrew Johnson
[EnvInject] - Loading node environment variables.
Building remotely on win32-1 (win32) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.14-win32s/ws/>
[epics-base-3.14-win32] $ cmd /c call C:\Users\jenkins\hudson3603332761583051569.bat
<https://jenkins.aps.anl.gov/job/epics-base-3.14-win32s/ws/>make> -O -j4 EPICS_HOST_ARCH=win32-x86-static
'make' is not recognized as an internal or external command,
operable program or batch file.
<https://jenkins.aps.anl.gov/job/epics-base-3.14-win32s/ws/>make> tapfiles EPICS_HOST_ARCH=win32-x86-static
<https://jenkins.aps.anl.gov/job/epics-base-3.14-win32s/ws/>exit> 9009
Build step 'Execute Windows batch command' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.win32-x86-static/*.tap
Did not find any matching files.
[WARNINGS] Skipping publisher since build result is FAILURE
Jenkins build is back to normal : epics-base-3.14-win32s #184 APS Jenkins
Build failed in Jenkins: epics-base-3.14-win32s #182 APS Jenkins
Prev: Build failed in Jenkins: epics-base-3.14-win32 #188 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.14-win32 #189 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Build failed in Jenkins: epics-base-3.14-win32s #182 APS Jenkins
Next: Jenkins build is back to normal : epics-base-3.14-win32s #184 APS Jenkins
