Subject: |
Re: Build failed in Jenkins: epics-base-3.15-win32s-test #108 |
Michael Davidsaver <[email protected]> |
To: |
[email protected] |
Date: |
Thu, 27 Apr 2017 13:10:42 -0400 |
On 04/24/2017 12:34 PM, APS Jenkins wrote:
> src/std/filters/test/O.win32-x86-static/arrTest.tap ............. ok
> src/std/filters/test/O.win32-x86-static/dbndTest.tap ............
> Failed 43/59 subtests
> src/std/filters/test/O.win32-x86-static/syncTest.tap ............ ok
> src/std/filters/test/O.win32-x86-static/tsTest.tap .............. ok
> src/std/rec/test/O.win32-x86-static/analogMonitorTest.tap ....... ok
> src/std/rec/test/O.win32-x86-static/arrayOpTest.tap ............. ok
> src/std/rec/test/O.win32-x86-static/regressTest.tap ............. ok
> Test Summary Report
> src/std/filters/test/O.win32-x86-static/dbndTest.tap (Wstat: 0 Tests: 16 Failed: 0)
> Parse errors: Bad plan. You planned 59 tests but ran 16.
> Files=72, Tests=8578, 6 wallclock secs ( 0.97 usr 0.48 sys + 0.35 cusr 3.57 csys = 5.37 CPU)
> Result: FAIL
> Build step 'Execute shell' marked build as failure
Running dbndTest through valgrind throws up a lot of invalid read
errors. These are presumably causing crashes in some cases. Seems to
be related to record field access.
- Build failed in Jenkins: epics-base-3.15-win32s-test #107 APS Jenkins
- Build failed in Jenkins: epics-base-3.15-win32s-test #108 APS Jenkins
Jenkins build is back to normal : epics-base-3.14 #247 APS Jenkins
Build failed in Jenkins: epics-base-3.15-win32s-test #111 APS Jenkins
<2017>
2025
2026
Build failed in Jenkins: epics-base-3.15-win64s-test #96 APS Jenkins
<2017>
2025
2026
