I did modify the records, which I mentioned in tech-talks as below:
http://www.aps.anl.gov/epics/tech-talk/2017/msg00690.php
Main focus are the following three items
1. recGblResetAlarms returns unsigned short / epicsUInt16
2. recGblCheckDeadband uses "unsigned (int) / epicsUInt32
3. db_post_events uses "unsigned int / epicsUInt32
So, I decided to minimize any changes on the monitor functions.
Please let me know what you think.
Han
diff --git src/std/rec/aSubRecord.c src/std/rec/aSubRecord.c
index 727c369..451dc62 100644
--- src/std/rec/aSubRecord.c
+++ src/std/rec/aSubRecord.c
@@ -441,10 +441,8 @@ static long get_alarm_double(DBADDR *paddr, struct dbr_alDouble *pad)
static void monitor(aSubRecord *prec)
- int i;
- unsigned short monitor_mask;
- monitor_mask = recGblResetAlarms(prec) | DBE_VALUE | DBE_LOG;
+ epicsUInt32 monitor_mask = (epicsUInt32) recGblResetAlarms(prec) | DBE_VALUE | DBE_LOG;
+ epicsInt32 i = 0;
/* Post events for VAL field */
if (prec->val != prec->oval) {
diff --git src/std/rec/aaiRecord.c src/std/rec/aaiRecord.c
index 43cb73b..0723bcc 100644
--- src/std/rec/aaiRecord.c
+++ src/std/rec/aaiRecord.c
@@ -280,10 +280,8 @@ static long get_control_double(DBADDR *paddr, struct dbr_ctrlDouble *pcd)
static void monitor(aaiRecord *prec)
- unsigned int hash = 0;
- monitor_mask = recGblResetAlarms(prec);
+ epicsUInt32 monitor_mask = (epicsUInt32) recGblResetAlarms(prec);
+ epicsUInt32 hash = 0;
if (prec->mpst == aaiPOST_Always)
monitor_mask |= DBE_VALUE;
diff --git src/std/rec/aaoRecord.c src/std/rec/aaoRecord.c
index 853b92c..f39989c 100644
--- src/std/rec/aaoRecord.c
+++ src/std/rec/aaoRecord.c
static void monitor(aaoRecord *prec)
if (prec->mpst == aaoPOST_Always)
diff --git src/std/rec/aiRecord.c src/std/rec/aiRecord.c
index 31ce25a..389053c 100644
--- src/std/rec/aiRecord.c
+++ src/std/rec/aiRecord.c
@@ -455,7 +455,7 @@ static void convert(aiRecord *prec)
static void monitor(aiRecord *prec)
- unsigned monitor_mask = recGblResetAlarms(prec);
/* check for value change */
recGblCheckDeadband(&prec->mlst, prec->val, prec->mdel, &monitor_mask, DBE_VALUE);
diff --git src/std/rec/aoRecord.c src/std/rec/aoRecord.c
index 3851de9..9a85a23 100644
--- src/std/rec/aoRecord.c
+++ src/std/rec/aoRecord.c
@@ -518,7 +518,7 @@ static void convert(aoRecord *prec, double value)
static void monitor(aoRecord *prec)
diff --git src/std/rec/biRecord.c src/std/rec/biRecord.c
index 7afea3d..c825275 100644
--- src/std/rec/biRecord.c
+++ src/std/rec/biRecord.c
@@ -227,9 +227,7 @@ static void checkAlarms(biRecord *prec)
static void monitor(biRecord *prec)
if (prec->mlst != prec->val){
/* post events for value change and archive change */
diff --git src/std/rec/boRecord.c src/std/rec/boRecord.c
index 537362c..26ed582 100644
--- src/std/rec/boRecord.c
+++ src/std/rec/boRecord.c
@@ -373,9 +373,8 @@ static void checkAlarms(boRecord *prec)
static void monitor(boRecord *prec)
diff --git src/std/rec/calcRecord.c src/std/rec/calcRecord.c
index 9c4e023..e965b95 100644
--- src/std/rec/calcRecord.c
+++ src/std/rec/calcRecord.c
@@ -395,12 +395,11 @@ static void checkAlarms(calcRecord *prec, epicsTimeStamp *timeLast)
static void monitor(calcRecord *prec)
- unsigned monitor_mask;
- double *pnew, *pprev;
- int i;
+ epicsFloat64 *pnew;
+ epicsFloat64 *pprev;
+ epicsInt32 i = 0;
diff --git src/std/rec/calcoutRecord.c src/std/rec/calcoutRecord.c
index da6cf42..aaaca75 100644
--- src/std/rec/calcoutRecord.c
+++ src/std/rec/calcoutRecord.c
@@ -624,12 +624,10 @@ static void execOutput(calcoutRecord *prec)
static void monitor(calcoutRecord *prec)
- double *pnew;
- double *pprev;
- int i;
+ epicsInt32 i = 0;
diff --git src/std/rec/compressRecord.c src/std/rec/compressRecord.c
index 4b4de5f..5186bf9 100644
--- src/std/rec/compressRecord.c
+++ src/std/rec/compressRecord.c
@@ -98,8 +98,8 @@ static void reset(compressRecord *prec)
static void monitor(compressRecord *prec)
- unsigned short alarm_mask = recGblResetAlarms(prec);
- unsigned short monitor_mask = alarm_mask | DBE_LOG | DBE_VALUE;
+ epicsUInt16 alarm_mask = recGblResetAlarms(prec);
+ epicsUInt32 monitor_mask = (epicsUInt32) alarm_mask | DBE_LOG | DBE_VALUE;
if (alarm_mask || prec->nuse != prec->ouse) {
db_post_events(prec, &prec->nuse, monitor_mask);
diff --git src/std/rec/dfanoutRecord.c src/std/rec/dfanoutRecord.c
index 76ee31b..07fd6a8 100644
--- src/std/rec/dfanoutRecord.c
+++ src/std/rec/dfanoutRecord.c
@@ -259,7 +259,7 @@ static void checkAlarms(dfanoutRecord *prec)
static void monitor(dfanoutRecord *prec)
diff --git src/std/rec/eventRecord.c src/std/rec/eventRecord.c
index 602023a..6171ad0 100644
--- src/std/rec/eventRecord.c
+++ src/std/rec/eventRecord.c
@@ -156,10 +156,8 @@ static long special(DBADDR *paddr, int after)
static void monitor(eventRecord *prec)
/* get previous stat and sevr and new stat and sevr*/
db_post_events(prec,&prec->val,monitor_mask|DBE_VALUE);
return;
diff --git src/std/rec/histogramRecord.c src/std/rec/histogramRecord.c
index 84010ee..d2cda8d 100644
--- src/std/rec/histogramRecord.c
+++ src/std/rec/histogramRecord.c
@@ -293,8 +293,8 @@ static long special(DBADDR *paddr, int after)
static void monitor(histogramRecord *prec)
- unsigned short monitor_mask = recGblResetAlarms(prec);
/* post events for count change */
if (prec->mcnt > prec->mdel){
monitor_mask |= DBE_VALUE | DBE_LOG;
diff --git src/std/rec/longinRecord.c src/std/rec/longinRecord.c
index dc7eb1b..6cc6951 100644
--- src/std/rec/longinRecord.c
+++ src/std/rec/longinRecord.c
@@ -356,7 +356,7 @@ static void checkAlarms(longinRecord *prec, epicsTimeStamp *timeLast)
static void monitor(longinRecord *prec)
if (prec->mdel < 0 ||
DELTA(prec->mlst, prec->val) > (epicsUInt32) prec->mdel) {
diff --git src/std/rec/longoutRecord.c src/std/rec/longoutRecord.c
index 8a9c1cf..6390770 100644
--- src/std/rec/longoutRecord.c
+++ src/std/rec/longoutRecord.c
@@ -329,7 +329,7 @@ static void checkAlarms(longoutRecord *prec)
static void monitor(longoutRecord *prec)
diff --git src/std/rec/lsiRecord.c src/std/rec/lsiRecord.c
index 81b6785..75cb655 100644
--- src/std/rec/lsiRecord.c
+++ src/std/rec/lsiRecord.c
@@ -187,7 +187,7 @@ static long special(DBADDR *paddr, int after)
static void monitor(lsiRecord *prec)
- epicsUInt16 events = recGblResetAlarms(prec);
+ epicsUInt32 events = (epicsUInt32) recGblResetAlarms(prec);
if (prec->len != prec->olen ||
memcmp(prec->oval, prec->val, prec->len)) {
diff --git src/std/rec/lsoRecord.c src/std/rec/lsoRecord.c
index 625f5d7..2a766fa 100644
--- src/std/rec/lsoRecord.c
+++ src/std/rec/lsoRecord.c
@@ -229,8 +229,8 @@ static long special(DBADDR *paddr, int after)
static void monitor(lsoRecord *prec)
events |= DBE_VALUE | DBE_LOG;
diff --git src/std/rec/mbbiDirectRecord.c src/std/rec/mbbiDirectRecord.c
index 3d1b3f8..93d9720 100644
--- src/std/rec/mbbiDirectRecord.c
+++ src/std/rec/mbbiDirectRecord.c
@@ -189,11 +189,11 @@ static long process(struct dbCommon *pcommon)
static void monitor(mbbiDirectRecord *prec)
- epicsUInt16 vl_events = events | DBE_VALUE | DBE_LOG;
+ epicsUInt32 vl_events = events | DBE_VALUE | DBE_LOG;
epicsUInt16 val = prec->val;
epicsUInt8 *pBn = &prec->b0;
- int i;
+ epicsInt32 i = 0;
/* Update B0 - BF from VAL and post monitors */
for (i = 0; i < NUM_BITS; i++, pBn++, val >>= 1) {
diff --git src/std/rec/mbbiRecord.c src/std/rec/mbbiRecord.c
index 72000f4..7245227 100644
--- src/std/rec/mbbiRecord.c
+++ src/std/rec/mbbiRecord.c
@@ -356,7 +356,7 @@ static void checkAlarms(mbbiRecord *prec, epicsTimeStamp *timeLast)
static void monitor(mbbiRecord *prec)
if (prec->mlst != prec->val) {
diff --git src/std/rec/mbboDirectRecord.c src/std/rec/mbboDirectRecord.c
index b807a98..3dfe866 100644
--- src/std/rec/mbboDirectRecord.c
+++ src/std/rec/mbboDirectRecord.c
@@ -307,7 +307,7 @@ static long special(DBADDR *paddr, int after)
static void monitor(mbboDirectRecord *prec)
diff --git src/std/rec/mbboRecord.c src/std/rec/mbboRecord.c
index c3e89a1..c854fdd 100644
--- src/std/rec/mbboRecord.c
+++ src/std/rec/mbboRecord.c
@@ -389,8 +389,8 @@ static void checkAlarms(mbboRecord *prec)
static void monitor(mbboRecord *prec)
prec->mlst = prec->val;
diff --git src/std/rec/permissiveRecord.c src/std/rec/permissiveRecord.c
index e553931..8bd1928 100644
--- src/std/rec/permissiveRecord.c
+++ src/std/rec/permissiveRecord.c
@@ -91,10 +91,12 @@ static long process(struct dbCommon *pcommon)
static void monitor(permissiveRecord *prec)
- unsigned short val,oval,wflg,oflg;
+ epicsUInt16 val = 0;
+ epicsUInt16 oval = 0;
+ epicsUInt16 wflg = 0;
+ epicsUInt16 oflg = 0;
/* get val,oval,wflg,oflg*/
val=prec->val;
oval=prec->oval;
diff --git src/std/rec/selRecord.c src/std/rec/selRecord.c
index de5e017..7ea7c5d 100644
--- src/std/rec/selRecord.c
+++ src/std/rec/selRecord.c
@@ -307,12 +307,10 @@ static void checkAlarms(selRecord *prec)
static void monitor(selRecord *prec)
- double *pnew;
- double *pprev;
- int i;
+ epicsInt32 i = 0;
diff --git src/std/rec/stateRecord.c src/std/rec/stateRecord.c
index ca5df02..6093d49 100644
--- src/std/rec/stateRecord.c
+++ src/std/rec/stateRecord.c
@@ -93,10 +93,8 @@ static long process(struct dbCommon *pcommon)
static void monitor(stateRecord *prec)
if(strncmp(prec->oval,prec->val,sizeof(prec->val))) {
db_post_events(prec,&(prec->val[0]),monitor_mask|DBE_VALUE|DBE_LOG);
strncpy(prec->oval,prec->val,sizeof(prec->val));
diff --git src/std/rec/stringinRecord.c src/std/rec/stringinRecord.c
index 28d4aae..5646e0b 100644
--- src/std/rec/stringinRecord.c
+++ src/std/rec/stringinRecord.c
@@ -157,8 +157,8 @@ static long process(struct dbCommon *pcommon)
static void monitor(stringinRecord *prec)
- int monitor_mask = recGblResetAlarms(prec);
if (strncmp(prec->oval, prec->val, sizeof(prec->val))) {
strncpy(prec->oval, prec->val, sizeof(prec->val));
diff --git src/std/rec/stringoutRecord.c src/std/rec/stringoutRecord.c
index 7ea2c4c..aec7bdc 100644
--- src/std/rec/stringoutRecord.c
+++ src/std/rec/stringoutRecord.c
@@ -185,8 +185,8 @@ static long process(struct dbCommon *pcommon)
static void monitor(stringoutRecord *prec)
diff --git src/std/rec/subArrayRecord.c src/std/rec/subArrayRecord.c
index 3de610c..c87c935 100644
--- src/std/rec/subArrayRecord.c
+++ src/std/rec/subArrayRecord.c
@@ -291,9 +291,7 @@ static long get_control_double(DBADDR *paddr, struct dbr_ctrlDouble *pcd)
static void monitor(subArrayRecord *prec)
monitor_mask |= (DBE_LOG|DBE_VALUE);
db_post_events(prec, prec->bptr, monitor_mask);
diff --git src/std/rec/subRecord.c src/std/rec/subRecord.c
index f440eca..68901fe 100644
--- src/std/rec/subRecord.c
+++ src/std/rec/subRecord.c
@@ -372,13 +372,12 @@ static void checkAlarms(subRecord *prec)
static void monitor(subRecord *prec)
- double *pnew;
- double *pold;
- int i;
/* get alarm mask */
+ epicsFloat64 *pold;
+ epicsInt32 i = 0;
diff --git src/std/rec/waveformRecord.c src/std/rec/waveformRecord.c
index 5d3963e..22dfce5 100644
--- src/std/rec/waveformRecord.c
+++ src/std/rec/waveformRecord.c
@@ -270,11 +270,9 @@ static long get_control_double(DBADDR *paddr, struct dbr_ctrlDouble *pcd)
static void monitor(waveformRecord *prec)
- unsigned short monitor_mask = 0;
if (prec->mpst == waveformPOST_Always)
if (prec->apst == waveformPOST_Always)
diff --git src/template/base/top/exampleApp/src/xxxRecord.c src/template/base/top/exampleApp/src/xxxRecord.c
index c2693c4..94fc938 100644
--- src/template/base/top/exampleApp/src/xxxRecord.c
+++ src/template/base/top/exampleApp/src/xxxRecord.c
@@ -241,10 +241,9 @@ static void checkAlarms(xxxRecord *prec)
static void monitor(xxxRecord *prec)
- double delta;
+ epicsFloat64 delta = 0.0;
delta = prec->mlst - prec->val;
if(delta<0.0) delta = -delta;
- Re: Patch file for Records which use consistent epics data types Michael Davidsaver
Jenkins build became unstable: epics-base-3.14 #249 APS Jenkins
<2017>
2025
2026
Jenkins build is back to stable : epics-base-3.14 #250 APS Jenkins
<2017>
2025
2026
