Please look at db_access.patch, and let me know what you think.
LAST_TYPE should be DBF_NO_ACCESS instead of DBF_DOUBLE, is it right?
Here are my environment as
$ git rev-parse HEAD
0bbb381efda8d48ab7d3f7c5f69efbeaa4674d98
$ git remote -v
origin https://git.launchpad.net/epics-base (fetch)
origin https://git.launchpad.net/epics-base (push)
I didn't commit my change anywhere, so I just generated the
db_access.patch via
$ git diff --no-prefix > db_access.patch
I just execute the following command (got from Michael)
$ git format-patch -k -1
It created the another enclosed file as 0001-ioc-rsrv-fix-C89-issue.patch
Han
diff --git src/ca/client/db_access.h src/ca/client/db_access.h
index 92aa5d0..99d441d 100644
--- src/ca/client/db_access.h
+++ src/ca/client/db_access.h
@@ -70,7 +70,7 @@ typedef epicsOldString dbr_class_name_t;
#define DBF_LONG 5
#define DBF_DOUBLE 6
#define DBF_NO_ACCESS 7
-#define LAST_TYPE DBF_DOUBLE
+#define LAST_TYPE DBF_NO_ACCESS
#define VALID_DB_FIELD(x) ((x >= 0) && (x <= LAST_TYPE))
#define INVALID_DB_FIELD(x) ((x < 0) || (x > LAST_TYPE))
>From 0bbb381efda8d48ab7d3f7c5f69efbeaa4674d98 Mon Sep 17 00:00:00 2001
Date: Tue, 2 May 2017 21:06:35 -0400
Subject: ioc/rsrv: fix C89 issue
src/ioc/rsrv/camessage.c | 5 ++---
1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/src/ioc/rsrv/camessage.c b/src/ioc/rsrv/camessage.c
index a174cb2..26a865a 100644
--- a/src/ioc/rsrv/camessage.c
+++ b/src/ioc/rsrv/camessage.c
@@ -1198,6 +1198,8 @@ static int claim_ciu_action ( caHdrLargeArray *mp,
int status;
struct channel_in_use *pciu;
+ struct dbChannel *dbch;
+ char *pName = (char *) pPayload;
* The available field is used (abused)
@@ -1210,9 +1212,6 @@ static int claim_ciu_action ( caHdrLargeArray *mp,
if (!CA_V44(client->minor_version_number))
return RSRV_ERROR; /* shouldn't actually get here due to VSUPPORTED test in camessage() */
- struct dbChannel *dbch;
- char *pName = (char *) pPayload;
* check the sanity of the message
2.1.4
- Re: Database Field type in db_access.h Michael Davidsaver
Re: changes to libCom/osi/os/osdThread.c to be used for RTEMS 4.12 Heinz Junkes
<2017>
2025
2026
Jenkins build is back to normal : epics-base-3.16-mac #101 APS Jenkins
<2017>
2025
2026
