2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Database Field type in db_access.h
To: Jeong Han Lee <[email protected]>, [email protected]
Date: Wed, 3 May 2017 08:13:47 -0400
On 05/03/2017 07:11 AM, Jeong Han Lee wrote:
> Hi,
>   Please look at db_access.patch, and let me know what you think.
>   LAST_TYPE should be DBF_NO_ACCESS instead of DBF_DOUBLE, is it right?
The present definition looks correct to me.  It did confuse me for a
moment until I noticed the '<='
> #define	VALID_DB_FIELD(x)	((x >= 0) && (x <= LAST_TYPE))
And similarly in dbf_type_is_valid().
It's actually not apparent to me that 'DBF_NO_ACCESS' can have any valid
use.  Other than appearing in dbf_text[] it doesn't seem to do anything.
And hey, what do you know.  RSRV isn't bounds checking the requested DBR
type code in event_add_action(), read_notify_action(), or read_action().
 It uses the dbr_size_n() macro which doesn't bounds check it's first
argument, or look for overflow.
>   I didn't commit my change anywhere, so I just generated the
> db_access.patch via
>   I just execute the following command (got from Michael)
> $ git format-patch -k -1
I should have mentioned that this command is only useful after you commit.
Re: Database Field type in db_access.h Jeong Han Lee
Prev: Database Field type in db_access.h Jeong Han Lee
Next: Re: Database Field type in db_access.h Jeong Han Lee
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
