2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Database Field type in db_access.h
To: Michael Davidsaver <[email protected]>, [email protected]
Date: Wed, 3 May 2017 15:27:11 +0200
Hi Michael,
  Please look at db_access.patch, and let me know what you think.
  LAST_TYPE should be DBF_NO_ACCESS instead of DBF_DOUBLE, is it right?
The present definition looks correct to me.  It did confuse me for a
moment until I noticed the '<='
#define	VALID_DB_FIELD(x)	((x >= 0) && (x <= LAST_TYPE))
  I don't follow your explanation. The present definition is following :
#define DBF_STRING	0
#define	DBF_INT		1
#define	DBF_SHORT	1
#define	DBF_FLOAT	2
#define	DBF_ENUM	3
#define	DBF_CHAR	4
#define	DBF_LONG	5
#define	DBF_DOUBLE	6
#define DBF_NO_ACCESS	7
#define	LAST_TYPE	DBF_DOUBLE
#define	INVALID_DB_FIELD(x)	((x < 0) || (x > LAST_TYPE))
If this is correct, what is DBF_NO_ACCESS within that definition? Is it in INVALID_DB_FIELD?
And similarly in dbf_type_is_valid().
Yes, I saw the similarity in dbf_type_is_valid(). In addition, However it is inconsistent if we compare DBR_* with DBF_*. That is the first very naive thought I had to create a patch. Then I think, it is more than what I think as usual.
  I found the interesting discussion in tech-talk.
  http://www.aps.anl.gov/epics/tech-talk/2002/msg00137.php
It's actually not apparent to me that 'DBF_NO_ACCESS' can have any valid
use.  Other than appearing in dbf_text[] it doesn't seem to do anything.
And hey, what do you know.  RSRV isn't bounds checking the requested DBR
type code in event_add_action(), read_notify_action(), or read_action().
 It uses the dbr_size_n() macro which doesn't bounds check it's first
argument, or look for overflow.
  I didn't commit my change anywhere, so I just generated the
db_access.patch via
  I just execute the following command (got from Michael)
$ git format-patch -k -1
I should have mentioned that this command is only useful after you commit.
I though so, but I prefer not to commit anything to anywhere. :) Once I understand the epics base better than, I will use this command to create a patch for the community. Thank you again.
  Han
P.S. Is this right place to discuss this subject? Or do anyone want me to move this subject to the normal tech-talk? It is the sort of question, which I have now, while I am studying more EPICS itself.
Re: Database Field type in db_access.h Michael Davidsaver
Database Field type in db_access.h Jeong Han Lee
Prev: Re: Database Field type in db_access.h Michael Davidsaver
Next: Jenkins build is back to normal : epics-base-3.16-mac #101 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Database Field type in db_access.h Michael Davidsaver
