2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Interest in JUnit xml Test Results?
To: EPICS core-talk <[email protected]>
Date: Mon, 15 May 2017 11:42:45 -0500
Hi Guys,
On Friday I came across a Perl program that converts TAP to JUnit XML.
It needs a Perl module XML::Generator which does not come with Perl, but
should be available for most Linux distro's or from CPAN. I have the
necessary build system changes to add that script and support a new
'make junitfiles' target (better names welcomed); as long as a user
doesn't build that target they shouldn't need the XML Perl module.
Any interest in adding this to Base, and if so to which branch? It
should allow the other CI systems which don't handle TAP to display test
results, and I might switch the APS Jenkins to use this since its TAP
module is flaky.
> tux% cat epicsEnvTest.tap
> 1..3
> ok  1 - epicsEnvSet correctly modifies environment
> ok  2 - Child thread sees parent environment values
> # Child and parent threads share a common environment
> ok  3 - PARENT environment variable not modified
becomes
> tux% cat epicsEnvTest.xml
> <testsuites>
>   <testsuite failures="0"
>              errors="0"
>              time="0"
>              tests="3"
>              name="epicsEnvTest"
>              id="1">
>     <testcase time="0"
>               name="Test_01"
>               classname="epicsEnvTest.Tests" />
>     <testcase time="0"
>               name="Test_02"
>     <testcase time="0"
>               name="Test_03"
>   </testsuite>
> </testsuites>
Test failures include the full "not ok" text, but #diagnostics are not
included in the XML output at all.
- Andrew
Re: Interest in JUnit xml Test Results? Ralph Lange
Prev: Jenkins build is back to normal : epics-base-3.15-win64-test #109 APS Jenkins
Next: Re: Interest in JUnit xml Test Results? Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: scanIoTest hangup on 3.15 (Cygwin) Andrew Johnson
