2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Interest in JUnit xml Test Results?
To: EPICS Core Talk <[email protected]>
Date: Tue, 16 May 2017 15:49:35 +0900
Hi Andrew,
That would be awesome. (EPICS tests don't work well with Appveyor CI because that doesn't understand TAP.)
Meanwhile I was looking at
which seems to add more complete information. See the example xml in the README on GitHub.
Not implemented in Perl, obviously.
As it is not related to any code, I would add it to all branches that we build using CI: 3.14/3.15/3.16
Related issue:
Can we make the tap or xunit targets also print the summary line (Result: PASS etc.) on stdout, i.e. add the commands that Michael uses on Travis? (find . -name '*.tap' -print0 | xargs -0 -n1 prove -e cat -f).
That would make grep'ing the make output (scrolling back or by script) a lot easier when running the tap/xunit style.
Cheers,
~Ralph
Re: Interest in JUnit xml Test Results? Andrew Johnson
Prev: Interest in JUnit xml Test Results? Andrew Johnson
Next: Re: Interest in JUnit xml Test Results? Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
