On 05/30/2017 06:42 PM, Andrew Johnson wrote:
> Hi Michael,
> On 05/25/2017 09:06 AM, Michael Davidsaver wrote:
>> I've realized that I need to hook into iocShutdown() to be able to
>> automatically shutdown QSRV during unittests. I need to do so during
>> the "stop" phase (eg. scanStop()) before records and lockSets are free'd.
>> My first though would be to use initHooks.h. So I'd like to add
>> * initHookAtShutdown - at start of iocShutdown()
>> * initHookAfterCloseLinks - after dbCaShutdown()
>> * initHookAtStopped - Just after iocShutdown() returns
> No objections in principle, but a cleaner option might be to add methods
> to the dbServer structure (which QSRV should support if possible) and
> make the rsrv_init(), rsrv_run() and rsrv_pause() calls in iocInit into
> calls to all registered servers through this interface. The
> dbRegisterServer() call in rsrv_init() would move into a registrar
> routine referenced in a new rsrv.dbd file.
I'm going to add the (de) initHooks anyway as this is something would
have been helpful to me before for driver work.
I don't see what you're getting at wrt. dbServer. How would this be
cleaner than an initHook? Seems the same to me. Were you thinking to
pass in some additional arguments?
> Will QSRV support pausing? This was added for DESY's hot-standby work; I
> don't see it as particularly important, but QSRV should probably display
> a warning message when someone tries to use it if it's not supported.
No plans. I hadn't considered this as I've never paused RSRV.
- Re: iocShutdown() hooks Andrew Johnson
- Re: iocShutdown() hooks Michael Davidsaver
- iocShutdown() hooks Michael Davidsaver
Build failed in Jenkins: epics-base-3.15-win64-test #112 APS Jenkins
Build failed in Jenkins: epics-base-3.15-win64-test #113 APS Jenkins
<2017>
2025
2026
<2017>
2025
2026
