Heinz,
> ## EPICS R3.16.0.1-DEV-fhi
Seeing the '-DEV', which revision are you building from? I think this
has been fixed already. For me this works with 3.16.1.
Michael
On 06/08/2017 10:27 AM, Heinz Junkes wrote:
> Hi,
> when I try to run an ioc on a system (linux-x86_64) where still some other ioc’s are running (standard Port in use) I see
> ## EPICS Base built Jun 8 2017
> xWidth = 100, yHeight = 100
> cas warning: Configured TCP port was unavailable.
> cas warning: Using dynamically assigned TCP port 36485,
> cas warning: but now two or more servers share the same UDP port.
> cas warning: Depending on your IP kernel this server may not be
> cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
> tryBind (Addr: 0xa141e01, Port: 5064) <————————— my debug output Addr 10.20.30.1, just bevor tryBind
> tryBind failed (Addr: 0xa141e01, Port: 5064) < ———————————— my debug output, tryBind failed (line 133 src/ioc/rsrv/caservertask.c)
> CAS: No TCP server started
> Thread _main_ (0x19c3f50) can't proceed, suspending.
> Dumping a stack trace of thread '_main_':
> [ 0x7ff760d43303]: /home/rtems/EPICS/add-rtems-4.12-api/lib/linux-x86_64/libCom.so.3.16.0(epicsStackTrace+0x73)
> [ 0x7ff760d32c05]: /home/rtems/EPICS/add-rtems-4.12-api/lib/linux-x86_64/libCom.so.3.16.0(cantProceed+0xc5)
> [ 0x7ff75fa2801a]: /home/rtems/EPICS/add-rtems-4.12-api/lib/linux-x86_64/libdbCore.so.3.16.0(rsrv_init+0x104a)
> [ 0x7ff75fa24bfb]: /home/rtems/EPICS/add-rtems-4.12-api/lib/linux-x86_64/libdbCore.so.3.16.0(iocBuild+0x2b)
> [ 0x7ff75fa24d89]: /home/rtems/EPICS/add-rtems-4.12-api/lib/linux-x86_64/libdbCore.so.3.16.0(iocInit+0x9)
> [ 0x7ff760d2d4e7]: /home/rtems/EPICS/add-rtems-4.12-api/lib/linux-x86_64/libCom.so.3.16.0(iocshBody+0xc17)
> [ 0x409b92]: ../../bin/linux-x86_64/IOCCryvisil(main+0x12)
> [ 0x7ff75ed84830]: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)
> [ 0x409be9]: ../../bin/linux-x86_64/IOCCryvisil(_start+0x29)
> Defining
> epicsEnvSet("EPICS_CAS_SERVER_PORT","5066”)
> in st.cmd solves the problem :
> Starting iocInit
> tryBind (Addr: 0xa141e01, Port: 5066)
> iocRun: All initialization complete
> ## Start any sequence programs
> #seq(sncxxx, "user=rtems")
> #startPVAServer
> epics>
> I am not using the actual src/ioc/rsrv/caservertask.c with the “autoMaxBytes” extension.
> Heinz
- Re: binding trouble if Port is already in use, src/ioc/rsrv/caservertask.c Heinz Junkes
- binding trouble if Port is already in use, src/ioc/rsrv/caservertask.c Heinz Junkes
<2017>
2025
2026
<2017>
2025
2026
