On 07/12/2017 05:28 PM, Heinz Junkes wrote:
> I'm just trying to write tests for the stdout/stderr mix up …
How do you plan to test this?
> In src/libCom/test most of the files are named epicsBlaBlaTest.c[pp] but some not
> e.g. ringPointerTest.c
> Is this intended?
> In the file, there is no epicsThreadCreate in main
Nor should there be. The main() thread is implicitly made an "epics"
thread in epicsThreadInit(). In osdThread.c look for a call to
init_threadInfo() in once().
> but an epicsThreadSetPriority call
> which leads to an error output from posix/osdThread.c -> “epicsThreadSetPriority called by non epics thread”
Seems like epicsThreadSetPriority() is missing a call to
epicsThreadInit(). Not sure if there are an side-effects to adding this.
You can verify this by adding a call to epicsThreadGetIdSelf() at some
point before the call to epicsThreadSetPriority().
> Should I fix this in ringPointerTest.c ( I would rename it to epicsRingPointerTest.c ;-) ) ?
I think a fix is necessary, but in osdThread.c rather than ringPointerTest.c
- libcom tests Heinz Junkes
libCom posix/Linux Heinz Junkes
<2017>
2025
2026
<2017>
2025
2026
