On 08/23/2017 12:23 PM, Marty Kraimer wrote:
> On 08/23/2017 12:09 PM, Heinz P. Junkes wrote:
>> There are still some issues to compile/run the V4 stuff. Even on linux
>> only
>> Attached you can find my used script.
>> There seems to be introduced a new directory structure (.../pv/...)
>> but this leads to issues like this:
>> ../../include/compiler/gcc -I../../include/os/Linux
>> -I../../include -I/home/etest/EPICS/pvDataCPP/include
>> -I/home/etest/EPICS/pvCommonCPP/include
>> -I/home/etest/EPICS/epics-base/include/compiler/gcc
>> -I/home/etest/EPICS/epics-base/include/os/Linux
>> -I/home/etest/EPICS/epics-base/include -c
>> ../../testApp/utils/testAtomicBoolean.cpp
>> In file included from ../../testApp/utils/testAtomicBoolean.cpp:4:0:
>> ../../src/remote/pv/remote.h:32:29: fatal error: pv/pvaConstants.h: No
>> such file or directory
>> #include <pv/pvaConstants.h>
>> compilation terminated.
>> make[2]: *** [testAtomicBoolean.o] Error
Do you see the same if you replace
> make runtests
with
> make
> make runtests
>> Heinz
>> #!/bin/bash
>> # Dependencies between modules, also used for RELEASE files
>> # pvDataCPP_DEPENDS_ON = pvCommonCPP
>> #normativeTypesCPP_DEPENDS_ON = pvDataCPP
>> # pvAccessCPP_DEPENDS_ON = pvDataCPP
>> # pvaClientCPP_DEPENDS_ON = pvAccessCPP normativeTypesCPP
>> # pvaSrv_DEPENDS_ON = pvAccessCPP
>> # pvDatabaseCPP_DEPENDS_ON = pvAccessCPP
>> # exampleCPP_DEPENDS_ON = pvDatabaseCPP pvaSrv pvaClientCPP
>> cat << EOF > RELEASE.local
>> PVACCESS=$PWD/pvAccessCPP
>> NORMATIVETYPES=$PWD/normativeTypesCPP
>> PVDATA=$PWD/pvDataCPP
>> PVDATABASE=$PWD/pvDatabaseCPP
>> PVCOMMON=$PWD/pvCommonCPP
>> PVACLIENT=$PWD/pvaClientCPP
>> PVASRV=$PWD/pvaSrv
>> EPICS_BASE=$PWD/epics-base
>> TEMPLATE_TOP=$PWD/epics-base/templates/makeBaseApp/top
>> EOF
> My RELEASE.local is:
> mrk> cat RELEASE.local
> EPICS4_DIR=/home/epicsv4/masterCPP
> EXAMPLE=${EPICS4_DIR}/exampleCPP
> PVDATABASE=${EPICS4_DIR}/pvDatabaseCPP
> PVACLIENT=${EPICS4_DIR}/pvaClientCPP
> PVASRV=${EPICS4_DIR}/pvaSrv
> PVACCESS=${EPICS4_DIR}/pvAccessCPP
> NORMATIVETYPES=${EPICS4_DIR}/normativeTypesCPP
> PVDATA=${EPICS4_DIR}/pvDataCPP
> #PVCOMMON=${EPICS4_DIR}/pvCommonCPP
> #EPICS_BASE=/home/install/epics/base-3.14.12.5
> #EPICS_BASE=/home/install/epics/base-3.15.5
> EPICS_BASE=/home/install/epics/base-3.16.1
> Thus all in reverse of dependencies.
> My build is successful.
> I am not sure what this means.
> Marty
>> repos=(
>> "https://github.com/epics-base/epics-base.git"
>> "https://github.com/epics-base/pvCommonCPP.git"
>> "https://github.com/epics-base/pvDataCPP.git"
>> "https://github.com/epics-base/normativeTypesCPP.git"
>> "https://github.com/epics-base/pvAccessCPP.git"
>> "https://github.com/epics-base/pvaClientCPP.git"
>> "https://github.com/epics-base/pvaSrv.git"
>> "https://github.com/epics-base/pvDatabaseCPP.git"
>> "https://github.com/epics-base/exampleCPP.git"
>> echo "Cloning " ${#repos[@]} "repositories"
>> for repo in "${repos[@]}"
>> do
>> localRepoDir=$(echo ${repo}| cut -d'/' -f5 | cut -d'.' -f1)
>> if [ -d $localRepoDir ]; then
>> echo "Directory " $localRepoDir " already exists"
>> cd $localRepoDir
>> echo "will pull"
>> git pull
>> make runtests
>> cd ..
>> else
>> echo "clone" ${repo}
>> git clone ${repo}
>> cd $localRepoDir
>> make runtests
>> cd ..
>> fi
>> done
- Re: Still can not successful compile/run epicsV4CPP from github Heinz P. Junkes
- Still can not successful compile/run epicsV4CPP from github Heinz P. Junkes
- Re: Still can not successful compile/run epicsV4CPP from github Marty Kraimer
Re: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Michael Davidsaver
<2017>
2025
2026
<2017>
2025
2026
