2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c
Cc: "[email protected]" <[email protected]>, "Slepicka, Hugo Henrique" <[email protected]>
Date: Wed, 23 Aug 2017 13:31:13 -0500
On 08/22/2017 05:42 PM, Andrew Johnson wrote:
> Declaring the flag variable as say
>         osiSockOptMcastLoop_t flag = 1;
> would seem to be a cleaner solution, and in line with how other OS
> socket API differences have been resolved in the past.
> Any objections to implementing this in Base-3.15?
This seems a reasonable way to go if test coverage is added as well.
Re: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Andrew Johnson
RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Heinz Junkes
Re: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Heinz Junkes
Re: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Michael Davidsaver
RE: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Williams Jr., Ernest L.
Prev: Re: Still can not successful compile/run epicsV4CPP from github Michael Davidsaver
Next: Re: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Heinz Junkes
