On 08/23/2017 01:31 PM, Michael Davidsaver wrote:
> This seems a reasonable way to go if test coverage is added as well.
Ok, the attached patch does everything except add the test coverage,
which will take me a little while to implement. I have cross-built the
result with MinGW but not MSVC yet. I will add this patch to the 3.15.5
Known Problems page so Ernest can use it, but I won't commit anything to
Git until I have the tests to go along with it.
I reserve the right to change my mind about using blockingSockTest.cpp
for these tests.
- Andrew
diff --git src/ca/client/udpiiu.cpp src/ca/client/udpiiu.cpp
index beae075..ccb2556 100644
--- src/ca/client/udpiiu.cpp
+++ src/ca/client/udpiiu.cpp
@@ -165,7 +165,7 @@ udpiiu::udpiiu (
#ifdef IP_ADD_MEMBERSHIP
- int flag = 1;
+ osiSockOptMcastLoop_t flag = 1;
if ( setsockopt ( this->sock, IPPROTO_IP, IP_MULTICAST_LOOP,
(char *) &flag, sizeof ( flag ) ) == -1 ) {
char sockErrBuf[64];
diff --git src/ioc/rsrv/caservertask.c src/ioc/rsrv/caservertask.c
index 50bc650..fda4421 100644
--- src/ioc/rsrv/caservertask.c
+++ src/ioc/rsrv/caservertask.c
@@ -308,7 +308,7 @@ void rsrv_build_addr_lists(void)
- int flag = 1;
if (setsockopt(beaconSocket, IPPROTO_IP, IP_MULTICAST_LOOP,
(char *)&flag, sizeof(flag))<0) {
diff --git src/libCom/osi/os/Darwin/osdSock.h src/libCom/osi/os/Darwin/osdSock.h
index 1d4556e..e7c3440 100644
--- src/libCom/osi/os/Darwin/osdSock.h
+++ src/libCom/osi/os/Darwin/osdSock.h
@@ -31,6 +31,7 @@ typedef int SOCKET;
#define socket_ioctl(A,B,C) ioctl(A,B,C)
typedef int osiSockIoctl_t;
typedef socklen_t osiSocklen_t;
+typedef int osiSockOptMcastLoop_t;
#define FD_IN_FDSET(FD) ((FD)<FD_SETSIZE)
diff --git src/libCom/osi/os/Linux/osdSock.h src/libCom/osi/os/Linux/osdSock.h
index 614f3f9..7164a54 100644
--- src/libCom/osi/os/Linux/osdSock.h
+++ src/libCom/osi/os/Linux/osdSock.h
@@ -35,6 +35,7 @@ typedef int SOCKET;
diff --git src/libCom/osi/os/RTEMS/osdSock.h src/libCom/osi/os/RTEMS/osdSock.h
index 930ed0e..6177c30 100644
--- src/libCom/osi/os/RTEMS/osdSock.h
+++ src/libCom/osi/os/RTEMS/osdSock.h
@@ -42,6 +42,7 @@ typedef int SOCKET;
+typedef char osiSockOptMcastLoop_t;
diff --git src/libCom/osi/os/WIN32/osdSock.h src/libCom/osi/os/WIN32/osdSock.h
index d92e187..2ff23c4 100644
--- src/libCom/osi/os/WIN32/osdSock.h
+++ src/libCom/osi/os/WIN32/osdSock.h
@@ -28,6 +28,7 @@
#define socket_ioctl(A,B,C) ioctlsocket(A,B,C)
typedef u_long FAR osiSockIoctl_t;
typedef int osiSocklen_t;
+typedef BOOL osiSockOptMcastLoop_t;
#ifndef SHUT_RD
# define SHUT_RD SD_RECEIVE
diff --git src/libCom/osi/os/cygwin32/osdSock.h src/libCom/osi/os/cygwin32/osdSock.h
index d642cad..75288c8 100644
--- src/libCom/osi/os/cygwin32/osdSock.h
+++ src/libCom/osi/os/cygwin32/osdSock.h
@@ -34,6 +34,7 @@ typedef int SOCKET;
#define FD_IN_FDSET(FD) ((FD)<FD_SETSIZE&&(FD)>=0)
#ifndef SHUT_RD
#define SHUT_RD 0
diff --git src/libCom/osi/os/freebsd/osdSock.h src/libCom/osi/os/freebsd/osdSock.h
index fe28d4c..b402ec1 100644
--- src/libCom/osi/os/freebsd/osdSock.h
+++ src/libCom/osi/os/freebsd/osdSock.h
@@ -36,6 +36,7 @@ typedef int SOCKET;
diff --git src/libCom/osi/os/iOS/osdSock.h src/libCom/osi/os/iOS/osdSock.h
index 0b3b3f6..08849a8 100644
--- src/libCom/osi/os/iOS/osdSock.h
+++ src/libCom/osi/os/iOS/osdSock.h
@@ -32,6 +32,7 @@ typedef int SOCKET;
diff --git src/libCom/osi/os/solaris/osdSock.h src/libCom/osi/os/solaris/osdSock.h
index a39c6c3..872a08d 100644
--- src/libCom/osi/os/solaris/osdSock.h
+++ src/libCom/osi/os/solaris/osdSock.h
@@ -42,6 +42,7 @@ typedef int osiSockIoctl_t;
#else
#endif
#define DOES_NOT_ACCEPT_ZERO_LENGTH_UDP
diff --git src/libCom/osi/os/vxWorks/osdSock.h src/libCom/osi/os/vxWorks/osdSock.h
index 80464ef..d949b25 100644
--- src/libCom/osi/os/vxWorks/osdSock.h
+++ src/libCom/osi/os/vxWorks/osdSock.h
@@ -65,6 +65,7 @@ typedef int SOCKET;
#define socket_ioctl(A,B,C) ioctl(A,B,(int)C)
- RE: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Williams Jr., Ernest L.
- RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Heinz Junkes
- Re: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Heinz Junkes
- Re: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Michael Davidsaver
- Re: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Andrew Johnson
Re: Still can not successful compile/run epicsV4CPP from github Heinz P. Junkes
<2017>
2025
2026
<2017>
2025
2026
