On 04/20/2017 10:19 AM, Michael Davidsaver wrote:
> I see that linux (circa 3.16) will accept either 'int' or 'char' for
> IP_MULTICAST_LOOP. Also for most other integer flags.
> I find references which suggest that winsock wants BOOL (which I assume
> is 'char').
> However, vxworks 5.5 clearly spec's 'int'.
> http://www.vxdev.com/docs/vx55man/vxworks/ref/sockLib.html
But as long as we're talking about Base-3.16 we don't have to support
VxWorks 5.5 at all. Wind River completely replaced the network stack in
VxWorks 6.x, and the newer stack looks like it will support either int
or char (there's code in setsockopt() for IP_MULTICAST_LOOP which
appears to handle both sizes, although they haven't updated the docs to
actually say that).
> Seems like the IP_MULTI* socket options need unit-test coverage. (maybe
> add to blockingSocketTest.cpp ?)
Agreed, and that seems like the right place for it.
- Andrew
- RE: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Williams Jr., Ernest L.
- RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Heinz Junkes
- Re: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Heinz Junkes
- Re: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Michael Davidsaver
Build failed in Jenkins: epics-base-3.15-win32 #275 APS Jenkins
<2017>
2025
2026
<2017>
2025
2026
