I see that linux (circa 3.16) will accept either 'int' or 'char' for
IP_MULTICAST_LOOP. Also for most other integer flags.
I find references which suggest that winsock wants BOOL (which I assume
is 'char').
However, vxworks 5.5 clearly spec's 'int'.
http://www.vxdev.com/docs/vx55man/vxworks/ref/sockLib.html
Ah, a well standardized API...
Seems like the IP_MULTI* socket options need unit-test coverage. (maybe
add to blockingSocketTest.cpp ?)
On 04/20/2017 07:42 AM, Heinz Junkes wrote:
> diff now in the right order, sorry;-)
> === modified file 'src/ioc/rsrv/caservertask.c'
> --- src/ioc/rsrv/caservertask.c 2016-05-22 12:38:18 +0000
> +++ src/ioc/rsrv/caservertask.c 2017-04-20 11:21:40 +0000
> @@ -307,13 +307,17 @@
> #ifdef IP_ADD_MEMBERSHIP
> +#if defined(__rtems__)
> + char flag = 1;
> +#else
> int flag = 1;
> +#endif
> if (setsockopt(beaconSocket, IPPROTO_IP, IP_MULTICAST_LOOP,
> (char *)&flag, sizeof(flag))<0) {
> char sockErrBuf[64];
> epicsSocketConvertErrnoToString (
> sockErrBuf, sizeof ( sockErrBuf ) );
> - errlogPrintf("rsrv: failed to set mcast loopback\n");
> + errlogPrintf("rsrv: failed to set mcast loopback (%d:%s)\n", errno, sockErrBuf);
> #endif
>> On 20 Apr 2017, at 13:27, Heinz Junkes <[email protected]> wrote:
>> With RTEMS (4.11.99, aka 4.12) setting the IP_MULTICAST_LOOP for the loopback gives
>> Had to use sizeof char as argument for the IP_MULTICAST_LOOP setsockopt call.
>> Changed it to
>> int intTrue = 1;
>> if (setsockopt (beaconSocket, SOL_SOCKET, SO_BROADCAST,
>> (char *)&intTrue, sizeof(intTrue))<0) {
>> cantProceed("CAS: online socket set up error\n");
>> char flag = 1;
>> #else
>> int flag = 1;
>> #endif
>> #endif
>> /* populate the interface address list (default is empty) */
>> rtems@epics:~/EPICS/add-rtems-4.12-api$ diff -Naur src/ioc/rsrv/caservertask.c /tmp/caservertask.c
>> --- src/ioc/rsrv/caservertask.c 2017-04-20 13:21:40.613544330 +0200
>> +++ /tmp/caservertask.c 2017-04-20 13:23:06.537549469 +0200
>> @@ -307,17 +307,13 @@
>> -#if defined(__rtems__)
>> - char flag = 1;
>> -#else
>> int flag = 1;
>> -#endif
>> - errlogPrintf("rsrv: failed to set mcast loopback (%d:%s)\n", errno, sockErrBuf);
>> + errlogPrintf("rsrv: failed to set mcast loopback\n");
>> #endif
- Re: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Andrew Johnson
- RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Heinz Junkes
- Re: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Heinz Junkes
<2017>
2025
2026
<2017>
2025
2026
