2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: exporting module versions
To: <[email protected]>
Date: Fri, 3 Nov 2017 12:12:47 -0500
On 11/03/2017 10:58 AM, Ralph Lange wrote:
> On Fri, Nov 3, 2017 at 3:59 PM, Dirk Zimoch <[email protected]>
> wrote:
>     I agree that all this is not easy.
>     Nevertheless, can we have version constants or functions in addition
>     to macros?
> Which version?
> Source code version? ABI version? API version? All of them? More?
Doesn't this also introduce a combinatorial problem too? If a module
like Asyn needed to alter its behaviour slightly based on the runtime
version of libCom that it's running against, wouldn't some modules
dependent on Asyn also have to do something similar? Programming is hard
enough for most people without having to add this level of complexity to
the development process.
Is there something in PSI's production environment that is pushing you
in this direction instead of accepting that you just need to rebuild
everything downstream of an update? I would recommend taking a look at
Sumo from HZB (BESSY-2) which automates all the necessary rebuilds.
- Andrew
Re: exporting module versions Dirk Zimoch
exporting module versions Michael Davidsaver
Re: exporting module versions Andrew Johnson
Re: exporting module versions Ralph Lange
RE: exporting module versions Mark Rivers
Re: exporting module versions Mark Rivers
Prev: Jenkins build is back to normal : epics-core » mac #10 APS Jenkins
Next: Jenkins build is back to normal : epics-core » linux32 #10 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: exporting module versions Ralph Lange
Next: Re: exporting module versions Dirk Zimoch
