2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS 7.0.1-pre1
To: <[email protected]>
Date: Wed, 22 Nov 2017 13:28:38 +0100
Hi everyone,
I have built EPICS 7.0.1-pre1 today for several vxWorks and embedded Linux target architectures. Unfortunately I have a number of build fails for architectures that used to work with 3.16.1.
Success:
Red Hat Enterprise Linux 7 64 bit with gcc and clang (host)
Scientific Linux 6 32 and 64 bit (cross from RHEL7)
ELDK 5.1 ppc 4xx and 5.2 ppc e500v2 32 bit
yocto 2.0 ppc e6500 64 bit
yocto 2.1 arm v8 64 bit (aarch64, Zynq)
Fail:
All vxWorks builds (6.2, 6.3, 6.6, 6.7 ppc603 and ppc604)
Montavista Linux 4.0 arm v5 (xscale, Moxa)
some unknown embedded Linux arm v6 (Moxa)
ELDK 4.2 ppc 4xx 32 bit
The vxWorks 6.2 and 6.3 builds failed here:
In file included from /usr/local/epics/base-7.0.1/include/os/vxWorks/boost/smart_ptr/detail/spinlock_pool.hpp:25, from /usr/local/epics/base-7.0.1/include/os/vxWorks/boost/smart_ptr/shared_ptr.hpp:38, from /usr/local/epics/base-7.0.1/include/os/vxWorks/boost/shared_ptr.hpp:17, from /usr/local/epics/base-7.0.1/include/os/vxWorks/boost/tr1/memory.hpp:56,
                 from ../../src/misc/pv/sharedPtr.h:133,
                 from ../pv/pvType.h:41,
                 from ../pv/pvIntrospect.h:17,
                 from ../pv/pvData.h:24,
                 from ../../src/json/print.cpp:11:
/usr/local/epics/base-7.0.1/include/os/vxWorks/boost/smart_ptr/detail/spinlock.hpp:47:52: boost/smart_ptr/detail/spinlock_pt.hpp: No such file or directory
The vxWorks 6.6 and 6.7 builds failed here:
../../src/misc/pv/typeCast.h: In function 'void<unnamed>::castVTyped(size_t, void*, const void*) [with TO = long long unsigned int, FROM = double]': ../../src/misc/pv/typeCast.h:168: sorry, unimplemented: inlining failed in call to 'TO epics::pvData::castUnsafe(const FROM&) [with TO = long long unsigned int, FROM = double]': function not considered for inlining
../../src/misc/typeCast.cpp:37: sorry, unimplemented: called from here
Two embedded Linux cross builds for Moxa serial servers fail here:
perl -CSD ../../src/env/bldEnvData.pl  -t moxa42-armv6l \
        -c gcc -s  /usr/local/epics/base-7.0.1/configure
Usage: bldEnvData.pl [options] configure
  -h       Help: Print this message
  -q       Quiet: Only print errors
  -o file  Output filename, default is envData.c
  -t arch  Target architecture $(T_A) name
  -s os    Operating system $(OS_CLASS)
  -c comp  Compiler class $(CMPLR_CLASS)
make[4]: *** No rule to make target `../O.Common/osiFileName.h', needed by `inc'. Stop. make[4]: Leaving directory `/afs/psi.ch/group/8431/dirk/git/BASE/base-7.0.1-pre1/modules/libcom/src/O.moxa42-armv6l'
ELDK 4.2 ppc 4xx cross build fails here:
../pvif.h: In constructor 'PDBSinglePut::PDBSinglePut(const std::tr1::shared_ptr<PDBSingleChannel>&, const std::tr1::shared_ptr<epics::pvAccess::ChannelPutRequester>&, const std::tr1::shared_ptr<epics::pvData::PVStructure>&)':
../pvif.h:291: error: 'FieldName::FieldName(const FieldName&)' is private
../pdbsingle.cpp:300: error: within this context
../pvif.h: In member function 'virtual void PDBSinglePut::put(const std::tr1::shared_ptr<epics::pvData::PVStructure>&, const std::tr1::shared_ptr<epics::pvData::BitSet>&)':
../pdbsingle.cpp:364: error: within this context
../pdbsingle.cpp:386: error: within this context
make[4]: *** [pdbsingle.o] Error 1
There are a a number of warnings (different for different target archs). Should we do something about them?
epicsTempFile.o: In function `epicsTempName':
epicsTempFile.cpp:(.text+0x2a): warning: the use of `tmpnam' is dangerous, better use `mkstemp'
In file included from ../../src/osi/os/Linux/osdFindAddr.c:10:
../../src/osi/os/posix/osdElfFindAddr.c: In function ‘epicsFindAddr’:
../../src/osi/os/posix/osdElfFindAddr.c:642: warning: cast to pointer from integer of different size
../../src/osi/os/vxWorks/osdFindSymbol.c: In function `epicsLoadLibrary':
../../src/osi/os/vxWorks/osdFindSymbol.c:48: warning: implicit declaration of function `close'
../../src/error/errlog.c: In function `errlogPrintf':
../../src/error/errlog.c:110: warning: 'nchar' might be used uninitialized in this function
../../src/osi/os/vxWorks/vxComLibrary.c: In function 'vxComLibrary':
../../src/osi/os/vxWorks/vxComLibrary.c:26: warning: 'symFindByNameEPICS' is deprecated (declared at ../../src/osi/os/vxWorks/epicsDynLink.h:30)
../../src/osi/os/vxWorks/veclist.c: In function 'veclist':
../../src/osi/os/vxWorks/veclist.c:76: warning: 'symFindByValue' is deprecated (declared at /afs/psi.ch/project/vxworks/VxWorks6.6/vxworks-6.6/target/h/symLib.h:119)
../tcpiiu.cpp: In member function `bool tcpiiu::processIncoming(const
   epicsTime&, callbackManager&)':
../tcpiiu.cpp:1212: warning: `arrayElementCount newsize' might be used
In file included from ../access.cpp:45:0:
../oldAccess.h:406:10: warning: ‘template<class> class std::auto_ptr’ is deprecated [-Wdeprecated-declarations]
     std::auto_ptr < CallbackGuard > pCallbackGuard;
In file included from /opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux/usr/include/c++/6.2.1/memory:81:0,
                 from ../oldAccess.h:29,
/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux/usr/include/c++/6.2.1/bits/unique_ptr.h:49:28: note: declared here
../Cap5.xs: In function ‘CA_put’:
../Cap5.xs:638:16: warning: ‘p.dbr’ may be used uninitialized in this function [-Wmaybe-uninitialized]
         status = ca_array_put(type, num_values, pch->chan, p.dbr);
../../../src/ioc/db/dbChannelIO.cpp:152:13: warning: comparison of constant -1 with expression of type 'unsigned short' is always true [-Wtautological-constant-out-of-range-compare]
            dbf_type_to_text ( dbChannelExportCAType ( this->dbch ) ),
/usr/local/epics/base-7.0.1/include/db_access.h:687:16: note: expanded from macro 'dbf_type_to_text'
    (  ((type) >= -1 && (type) < dbf_text_dim-2) ? \
In file included from ../../../src/ioc/db/dbContext.cpp:29:0:
../../../src/ioc/db/dbCAC.h:197:10: warning: ‘template<class> class std::auto_ptr’ is deprecated [-Wdeprecated-declarations]
     std::auto_ptr < cacContext > pNetContext;
                 from ../../../src/ioc/db/dbCAC.h:29,
   template<typename> class auto_ptr;
../../../src/ioc/db/dbChannelIO.cpp: In member function 'virtual void dbChannelIO::show(epicsGuard<epicsMutex>&, unsigned int) const': ../../../src/ioc/db/dbChannelIO.cpp:152: warning: comparison is always true due to limited range of data type
../../../src/ioc/dbStatic/dbStaticLib.c: In function 'dbGetStringNum':
../../../src/ioc/dbStatic/dbStaticLib.c:2126: warning: comparison is always false due to limited range of data type ../../../src/ioc/dbStatic/dbStaticLib.c:2146: warning: comparison is always false due to limited range of data type
../../../src/ioc/rsrv/camessage.c: In function 'read_action':
../../../src/ioc/rsrv/camessage.c:630: warning: comparison is always false due to limited range of data type
../../../src/ioc/rsrv/camessage.c: In function 'read_notify_action':
../../../src/ioc/rsrv/camessage.c:721: warning: comparison is always false due to limited range of data type
../../../src/ioc/rsrv/camessage.c: In function 'event_add_action':
../../../src/ioc/rsrv/camessage.c:1787: warning: comparison is always false due to limited range of data type
../../../src/std/link/lnkCalc.c: In function `lnkCalc_string':
../../../src/std/link/lnkCalc.c:184: warning: subscript has type `char'
../../src/misc/reftrack.cpp:268:15: warning: unused variable 'now' [-Wunused-variable]
    epicsTime now(epicsTime::getCurrent());
../../src/factory/FieldCreateFactory.cpp: In member function 'epics::pvData::int32 epics::pvData::Union::guess(epics::pvData::Type, epics::pvData::ScalarType) const': ../../src/factory/FieldCreateFactory.cpp:625: warning: 'type' may be used uninitialized in this function
../../src/misc/pv/reftrack.h:108: warning: 'class epics::RefMonitor' has virtual functions but non-virtual destructor
In file included from ../../testApp/misc/testThread.cpp:26: /usr/local/epics/base-7.0.1/include/pv/executor.h:37: warning: ‘Command’ is deprecated (declared at /usr/local/epics/base-7.0.1/include/pv/executor.h:35) /usr/local/epics/base-7.0.1/include/pv/executor.h:37: warning: ‘Command’ is deprecated (declared at /usr/local/epics/base-7.0.1/include/pv/executor.h:35) /usr/local/epics/base-7.0.1/include/pv/executor.h:37: warning: ‘Command’ is deprecated (declared at /usr/local/epics/base-7.0.1/include/pv/executor.h:35) /usr/local/epics/base-7.0.1/include/pv/executor.h:37: warning: ‘Command’ is deprecated (declared at /usr/local/epics/base-7.0.1/include/pv/executor.h:35) /usr/local/epics/base-7.0.1/include/pv/executor.h:59: warning: ‘Executor’ is deprecated (declared at /usr/local/epics/base-7.0.1/include/pv/executor.h:57) /usr/local/epics/base-7.0.1/include/pv/executor.h:59: warning: ‘Executor’ is deprecated (declared at /usr/local/epics/base-7.0.1/include/pv/executor.h:57) /usr/local/epics/base-7.0.1/include/pv/executor.h:59: warning: ‘Executor’ is deprecated (declared at /usr/local/epics/base-7.0.1/include/pv/executor.h:57) /usr/local/epics/base-7.0.1/include/pv/executor.h:59: warning: ‘Executor’ is deprecated (declared at /usr/local/epics/base-7.0.1/include/pv/executor.h:57)
In file included from ../../testApp/misc/testThread.cpp:27:
/usr/local/epics/base-7.0.1/include/pv/timeFunction.h:31: warning: ‘TimeFunctionRequester’ is deprecated (declared at /usr/local/epics/base-7.0.1/include/pv/timeFunction.h:29) /usr/local/epics/base-7.0.1/include/pv/timeFunction.h:31: warning: ‘TimeFunctionRequester’ is deprecated (declared at /usr/local/epics/base-7.0.1/include/pv/timeFunction.h:29) /usr/local/epics/base-7.0.1/include/pv/timeFunction.h:31: warning: ‘TimeFunctionRequester’ is deprecated (declared at /usr/local/epics/base-7.0.1/include/pv/timeFunction.h:29) /usr/local/epics/base-7.0.1/include/pv/timeFunction.h:31: warning: ‘TimeFunctionRequester’ is deprecated (declared at /usr/local/epics/base-7.0.1/include/pv/timeFunction.h:29) /usr/local/epics/base-7.0.1/include/pv/timeFunction.h:50: warning: ‘TimeFunction’ is deprecated (declared at /usr/local/epics/base-7.0.1/include/pv/timeFunction.h:48) /usr/local/epics/base-7.0.1/include/pv/timeFunction.h:50: warning: ‘TimeFunction’ is deprecated (declared at /usr/local/epics/base-7.0.1/include/pv/timeFunction.h:48) /usr/local/epics/base-7.0.1/include/pv/timeFunction.h:50: warning: ‘TimeFunction’ is deprecated (declared at /usr/local/epics/base-7.0.1/include/pv/timeFunction.h:48) /usr/local/epics/base-7.0.1/include/pv/timeFunction.h:50: warning: ‘TimeFunction’ is deprecated (declared at /usr/local/epics/base-7.0.1/include/pv/timeFunction.h:48)
../../testApp/misc/testThread.cpp: In function ‘void testBasic()’:
../../testApp/misc/testThread.cpp:105: warning: ‘Executor’ is deprecated (declared at /usr/local/epics/base-7.0.1/include/pv/executor.h:57)
/usr/local/epics/base-7.0.1/include/pv/anyscalar.h: In function ‘void<unnamed>::test_basic()’: /usr/local/epics/base-7.0.1/include/pv/anyscalar.h:98: warning: dereferencing pointer ‘<anonymous>’ does break strict-aliasing rules /usr/local/epics/base-7.0.1/include/pv/anyscalar.h:98: note: initialized from here ../../testApp/misc/testanyscalar.cpp:54: warning: dereferencing pointer ‘<anonymous>’ does break strict-aliasing rules
../../testApp/misc/testanyscalar.cpp:54: note: initialized from here
/usr/local/epics/base-7.0.1/include/pv/typemap.h:16: warning: dereferencing pointer ‘<anonymous>’ does break strict-aliasing rules /usr/local/epics/base-7.0.1/include/pv/anyscalar.h:85: note: initialized from here /usr/local/epics/base-7.0.1/include/pv/typemap.h:17: warning: dereferencing pointer ‘<anonymous>’ does break strict-aliasing rules /usr/local/epics/base-7.0.1/include/pv/anyscalar.h:85: note: initialized from here /usr/local/epics/base-7.0.1/include/pv/typemap.h:18: warning: dereferencing pointer ‘<anonymous>’ does break strict-aliasing rules /usr/local/epics/base-7.0.1/include/pv/anyscalar.h:85: note: initialized from here /usr/local/epics/base-7.0.1/include/pv/typemap.h:19: warning: dereferencing pointer ‘<anonymous>’ does break strict-aliasing rules /usr/local/epics/base-7.0.1/include/pv/anyscalar.h:85: note: initialized from here /usr/local/epics/base-7.0.1/include/pv/typemap.h:20: warning: dereferencing pointer ‘<anonymous>’ does break strict-aliasing rules /usr/local/epics/base-7.0.1/include/pv/anyscalar.h:85: note: initialized from here ../../testApp/misc/testanyscalar.cpp:67: warning: dereferencing pointer ‘<anonymous>’ does break strict-aliasing rules
../../testApp/misc/testanyscalar.cpp:67: note: initialized from here
../../testApp/misc/testanyscalar.cpp:69: warning: dereferencing pointer ‘<anonymous>’ does break strict-aliasing rules
../../testApp/misc/testanyscalar.cpp:69: note: initialized from here
/usr/local/epics/base-7.0.1/include/pv/anyscalar.h: In function ‘void<unnamed>::test_ctor()’: /usr/local/epics/base-7.0.1/include/pv/anyscalar.h:98: warning: dereferencing pointer ‘<anonymous>’ does break strict-aliasing rules /usr/local/epics/base-7.0.1/include/pv/anyscalar.h:98: note: initialized from here ../../testApp/misc/testanyscalar.cpp:39: warning: dereferencing pointer ‘<anonymous>’ does break strict-aliasing rules
../../testApp/misc/testanyscalar.cpp:39: note: initialized from here
/usr/local/epics/base-7.0.1/include/pv/anyscalar.h: In function ‘void<unnamed>::test_swap()’: /usr/local/epics/base-7.0.1/include/pv/anyscalar.h:98: warning: dereferencing pointer ‘<anonymous>’ does break strict-aliasing rules /usr/local/epics/base-7.0.1/include/pv/anyscalar.h:98: note: initialized from here ../../testApp/misc/testanyscalar.cpp:126: warning: dereferencing pointer ‘<anonymous>’ does break strict-aliasing rules
../../testApp/misc/testanyscalar.cpp:126: note: initialized from here
/usr/local/epics/base-7.0.1/include/pv/anyscalar.h:98: warning: dereferencing pointer ‘<anonymous>’ does break strict-aliasing rules /usr/local/epics/base-7.0.1/include/pv/anyscalar.h:98: note: initialized from here ../../testApp/misc/testanyscalar.cpp:145: warning: dereferencing pointer ‘<anonymous>’ does break strict-aliasing rules
../../testApp/misc/testanyscalar.cpp:145: note: initialized from here
/usr/local/epics/base-7.0.1/include/pv/anyscalar.h:98: warning: dereferencing pointer ‘<anonymous>’ does break strict-aliasing rules /usr/local/epics/base-7.0.1/include/pv/anyscalar.h:98: note: initialized from here ../../testApp/misc/testanyscalar.cpp:153: warning: dereferencing pointer ‘<anonymous>’ does break strict-aliasing rules
../../testApp/misc/testanyscalar.cpp:153: note: initialized from here
/usr/local/epics/base-7.0.1/include/pv/anyscalar.h:98: warning: dereferencing pointer ‘<anonymous>’ does break strict-aliasing rules /usr/local/epics/base-7.0.1/include/pv/anyscalar.h:98: note: initialized from here ../../testApp/misc/testanyscalar.cpp:159: warning: dereferencing pointer ‘<anonymous>’ does break strict-aliasing rules
../../testApp/misc/testanyscalar.cpp:159: note: initialized from here
/usr/local/epics/base-7.0.1/include/pv/anyscalar.h:98: warning: dereferencing pointer ‘<anonymous>’ does break strict-aliasing rules /usr/local/epics/base-7.0.1/include/pv/anyscalar.h:98: note: initialized from here /usr/local/epics/base-7.0.1/include/pv/anyscalar.h:98: warning: dereferencing pointer ‘<anonymous>’ does break strict-aliasing rules /usr/local/epics/base-7.0.1/include/pv/anyscalar.h:98: note: initialized from here ../../testApp/misc/testanyscalar.cpp:164: warning: dereferencing pointer ‘<anonymous>’ does break strict-aliasing rules
../../testApp/misc/testanyscalar.cpp:164: note: initialized from here
../../testApp/misc/testanyscalar.cpp:165: warning: dereferencing pointer ‘<anonymous>’ does break strict-aliasing rules
../../testApp/misc/testanyscalar.cpp:165: note: initialized from here
../../testApp/copy/testPVCopy.cpp: In function 'void testPVScalar(const string&, const string&, const PVStructurePtr&, const PVCopyPtr&)': ../../testApp/copy/testPVCopy.cpp:44:12: warning: variable 'offset' set but not used [-Wunused-but-set-variable] ../../testApp/copy/testPVCopy.cpp: In function 'void testPVScalarArray(const string&, const string&, const PVStructurePtr&, const PVCopyPtr&)': ../../testApp/copy/testPVCopy.cpp:90:12: warning: variable 'offset' set but not used [-Wunused-but-set-variable]
../../testApp/misc/testQueue.cpp:68:28: warning: 'Queue' is deprecated (declared at /usr/local/epics/base-7.0.1/include/pv/queue.h:28) [-Wdeprecated-declarations]
In file included from ../../src/remote/codec.cpp:40:
../../src/remote/pv/codec.h:294:18: warning: private field '_socketSendBufferSize' is not used [-Wunused-private-field]
    const size_t _socketSendBufferSize;
In file included from ../caProvider.cpp:21:0:
../caChannel.h:93:46: warning: ‘virtual void epics::pvAccess::ca::CAChannel::destroy()’ is deprecated [-Wdeprecated-declarations]
     virtual void destroy() EPICS_DEPRECATED {};
../caChannel.h:93:18: note: declared here
../caChannel.h:171:46: warning: ‘virtual void epics::pvAccess::ca::CAChannelGet::destroy()’ is deprecated [-Wdeprecated-declarations]
../caChannel.h:171:18: note: declared here
../caChannel.h:239:46: warning: ‘virtual void epics::pvAccess::ca::CAChannelPut::destroy()’ is deprecated [-Wdeprecated-declarations]
../caChannel.h:239:18: note: declared here
../caChannel.h:302:46: warning: ‘virtual void epics::pvAccess::ca::CAChannelMonitor::destroy()’ is deprecated [-Wdeprecated-declarations]
../caChannel.h:302:18: note: declared here
../reftrackioc.cpp: In function 'void {anonymous}::showRefs(const epics::RefSnapshot&, int, bool)': ../reftrackioc.cpp:29:75: warning: format '%zd' expects argument of type 'signed size_t', but argument 4 has type 'long int' [-Wformat]
../../testApp/remote/testGetPerformance.cpp: In function ‘void get_all()’:
../../testApp/remote/testGetPerformance.cpp:117: warning: ‘virtual void epics::pvAccess::ChannelProvider::flush()’ is deprecated (declared at /usr/local/epics/base-7.0.1/include/pv/pvAccess.h:1244)
../../testApp/remote/testGetPerformance.cpp: In function ‘void runTest()’:
../../testApp/remote/testGetPerformance.cpp:324: warning: ‘virtual void epics::pvAccess::ChannelProvider::flush()’ is deprecated (declared at /usr/local/epics/base-7.0.1/include/pv/pvAccess.h:1244) ../../testApp/remote/testGetPerformance.cpp:358: warning: ‘virtual void epics::pvAccess::ChannelProvider::flush()’ is deprecated (declared at /usr/local/epics/base-7.0.1/include/pv/pvAccess.h:1244)
../../testApp/utils/configurationTest.cpp:35:19: warning: unused variable 'indata' [-Wunused-const-variable]
static const char indata[] =
../../testApp/utils/configurationTest.cpp:43:19: warning: unused variable 'expectdata' [-Wunused-const-variable]
static const char expectdata[] =
In file included from ../ntcontinuum.cpp:8:
../pv/ntcontinuum.h:96:14: warning: private field 'dim' is not used [-Wunused-private-field]
        bool dim;
../pv/nthistogram.h:106:14: warning: private field 'dim' is not used [-Wunused-private-field]
        bool dim;
In file included from ../pvaClient.cpp:19:
../pv/pvaClient.h:1742:10: warning: 'epics::pvaClient::PvaClientMonitor::monitorConnect' hides overloaded virtual function [-Woverloaded-virtual]
    void monitorConnect(
../pv/pvaClient.h:1610:18: note: hidden overloaded virtual function 'epics::pvaClient::PvaClientMonitorRequester::monitorConnect' declared here: type mismatch at 2nd parameter ('const PvaClientMonitorPtr &' (aka 'const shared_ptr<epics::pvaClient::PvaClientMonitor> &') vs 'const epics::pvData::MonitorPtr &' (aka 'const shared_ptr<epics::pvAccess::Monitor> &'))
    virtual void monitorConnect(epics::pvData::Status const & status,
../pv/pvaClient.h:1746:10: warning: 'epics::pvaClient::PvaClientMonitor::unlisten' hides overloaded virtual function [-Woverloaded-virtual]
    void unlisten(epics::pvData::MonitorPtr const & monitor);
../pv/pvaClient.h:1623:18: note: hidden overloaded virtual function 'epics::pvaClient::PvaClientMonitorRequester::unlisten' declared here: different number of parameters (0 vs 1)
    virtual void unlisten()
../../src/pvAccess/channelLocal.cpp: In member function ‘void epics::pvDatabase::ChannelRPCLocal::processRequest(const epics::pvAccess::RPCService::shared_pointer&, const epics::pvData::PVStructurePtr&)’: ../../src/pvAccess/channelLocal.cpp:828: warning: ‘virtual void epics::pvDatabase::ChannelRPCLocal::destroy()’ is deprecated (declared at ../../src/pvAccess/channelLocal.cpp:740) ../../src/pvAccess/channelLocal.cpp: In member function ‘void epics::pvDatabase::ChannelRPCLocal::processRequest(const epics::pvAccess::RPCServiceAsync::shared_pointer&, const epics::pvData::PVStructurePtr&)’: ../../src/pvAccess/channelLocal.cpp:846: warning: ‘virtual void epics::pvDatabase::ChannelRPCLocal::destroy()’ is deprecated (declared at ../../src/pvAccess/channelLocal.cpp:740) ../../src/pvAccess/channelLocal.cpp:857: warning: ‘virtual void epics::pvDatabase::ChannelRPCLocal::destroy()’ is deprecated (declared at ../../src/pvAccess/channelLocal.cpp:740)
../../test/src/testLocalProvider.cpp: In function ‘void test()’:
../../test/src/testLocalProvider.cpp:74: warning: ‘virtual void epics::pvDatabase::ChannelProviderLocal::destroy()’ is deprecated (declared at /usr/local/epics/base-7.0.1/include/pv/channelProviderLocal.h:124)
../../test/src/testPVAServer.cpp: In function ‘void test()’:
../../test/src/testPVAServer.cpp:70: warning: ‘void epics::pvAccess::ServerContext::destroy()’ is deprecated (declared at /usr/local/epics/base-7.0.1/include/pv/serverContext.h:59)
../pdbsingle.cpp:300:64: warning: C++98 requires an accessible copy constructor for class 'FieldName' when binding a reference to a temporary; was private [-Wbind-to-temporary-copy] ,pvif(channel->pv->builder->attach(channel->pv->chan, pvf, FieldName()))
../pvif.h:291:5: note: declared private here
    FieldName(const FieldName&);
../pdbsingle.cpp:364:92: warning: C++98 requires an accessible copy constructor for class 'FieldName' when binding a reference to a temporary; was private [-Wbind-to-temporary-copy] p2p::auto_ptr<PVIF> putpvif(channel->pv->builder->attach(channel->pv->chan, value, FieldName()));
../pdbsingle.cpp:386:92: warning: C++98 requires an accessible copy constructor for class 'FieldName' when binding a reference to a temporary; was private [-Wbind-to-temporary-copy] p2p::auto_ptr<PVIF> putpvif(channel->pv->builder->attach(channel->pv->chan, value, FieldName()));
/usr/local/epics/base-7.0.1/include/pv/anyscalar.h: In function ‘int<unnamed>::conf_integer(void*, epics::pvData::yajl::integer_arg)’: /usr/local/epics/base-7.0.1/include/pv/anyscalar.h:98: warning: dereferencing pointer ‘<anonymous>’ does break strict-aliasing rules /usr/local/epics/base-7.0.1/include/pv/anyscalar.h:98: note: initialized from here
Dirk
Re: EPICS 7.0.1-pre1 Michael Davidsaver
Re: EPICS 7.0.1-pre1 (typeCast.h) Michael Davidsaver
Re: EPICS 7.0.1-pre1 (pdbsingle.cpp) Michael Davidsaver
Re: EPICS 7.0.1-pre1 (spinlock.hpp) Dirk Zimoch
Re: EPICS 7.0.1-pre1 (client.cpp) Dirk Zimoch
Re: EPICS 7.0.1-pre1 -- vxWorks 6.2 Dirk Zimoch
Re: EPICS 7.0.1-pre1 (non-virtual destructors) Dirk Zimoch
Re: EPICS 7.0.1-pre1 (epicsException.h) Dirk Zimoch
EPICS 7.0.1-pre1 Andrew Johnson
Prev: Re: EPICS 7.0.1-pre1 Andrew Johnson
Next: Re: EPICS 7.0.1-pre1 Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS 7.0.1-pre1 Michael Davidsaver
