2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS 7.0.1-pre1 -- vxWorks 6.2
To: <[email protected]>
Date: Fri, 24 Nov 2017 11:19:15 +0100
vxWorks 6.2 now fails here:
In file included from ../../src/misc/pvUnitTest.cpp:12:
../../src/misc/pv/pvUnitTest.h: In function `detail::testPassx
testFieldEqual(const boost::shared_ptr<const epics::pvData::PVStructure>&,
   const char*, typename PVD::value_type)':
../../src/misc/pv/pvUnitTest.h:156: error: syntax error before `>' token
../../src/misc/pv/pvUnitTest.h:158: error: syntax error before `>' token
../../src/misc/pv/pvUnitTest.h:160: error: syntax error before `>' token
   const char*, typename PVD::const_svector)':
../../src/misc/pv/pvUnitTest.h:177: error: syntax error before `>' token
make[4]: *** [pvUnitTest.o] Error 1
The code is:
    typename PVD::const_shared_pointer fval(val->getSubField<PVD>(name));
It seems the compiler (gcc 3.3.2) does not yet know the syntax function<typename>()
After taking pvUnitTest.cpp out it fails in PVDataCreateFactory.cpp with the same problem.
It seems gcc 3.3.2 is too old and thus EPICS 7 cannot be used on vxWorks 6.2.
Dirk
Re: EPICS 7.0.1-pre1 -- vxWorks 6.2 Dirk Zimoch
EPICS 7.0.1-pre1 Andrew Johnson
Re: EPICS 7.0.1-pre1 Dirk Zimoch
Prev: Re: EPICS 7.0.1-pre1 (client.cpp) Dirk Zimoch
Next: Re: EPICS 7.0.1-pre1 Dirk Zimoch
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: EPICS 7.0.1-pre1 -- vxWorks 6.2 Dirk Zimoch
