On 23.11.2017 09:50, Dirk Zimoch wrote:
I have changed "FORCE_INLINE" to "inline" in typeCast.h line 168
function castUnsafe and tried to build again.
Now typeCast.cpp compiles.
The build fails now in dbsingle.cpp like the other vxWorks builds.
Correction: Not like the other vxWorks builds but like the ELDK 4.2
build. Details to that fault come in the other branch of this
communication.
On 23.11.2017 08:50, Dirk Zimoch wrote:
On 22.11.2017 16:51, Michael Davidsaver wrote:
On 11/22/2017 06:28 AM, Dirk Zimoch wrote:
The vxWorks 6.6 and 6.7 builds failed here:
../../src/misc/pv/typeCast.h: In function
'void<unnamed>::castVTyped(size_t, void*, const void*) [with TO = long
long unsigned int, FROM = double]':
../../src/misc/pv/typeCast.h:168: sorry, unimplemented: inlining failed
in call to 'TO epics::pvData::castUnsafe(const FROM&) [with TO = long
long unsigned int, FROM = double]': function not considered for
inlining
../../src/misc/typeCast.cpp:37: sorry, unimplemented: called from here
Which GCC version is involved here? It seems like the logic controlling
FORCE_INLINE in templateMeta.h needs to be adjusted.
https://github.com/epics-base/pvDataCPP/blob/master/src/misc/pv/templateMeta.h#L13
This is the gcc that comes with vxWorks:
vxWorks 6.6:
gcc version 4.1.2 (Wind River VxWorks G++ 4.1-82)
vxWorks 6.7:
gcc version 4.1.2 (Wind River VxWorks G++ DWARF-EH 4.1-131)
It gets "__attribute__((always_inline)) inline" and understands it. It
just does not like inlining that particular function, but does not say
why.
Here is the pre-processed code:
# 167 "../../src/misc/pv/typeCast.h"
template<typename TO, typename FROM>
static __attribute__((always_inline)) inline TO castUnsafe(const FROM&
from)
return detail::cast_helper<TO,FROM>::op(from);
__attribute__ ((visibility("default"))) extern void castUnsafeV(size_t
count, ScalarType to, void *dest, ScalarType from, const void *src);
It is called from here:
namespace {
static void noconvert(size_t, void*, const void*)
throw std::runtime_error("castUnsafeV: Conversion not supported");
static void castVTyped(size_t count, void *draw, const void *sraw)
TO *dest=(TO*)draw;
const FROM *src=(FROM*)sraw;
const FROM *last = src+count;
try {
while (src != last) {
*dest = castUnsafe<TO,FROM>(*src);
++dest; ++src;
} catch (std::exception& ex) {
- EPICS 7.0.1-pre1 Andrew Johnson
- Re: EPICS 7.0.1-pre1 Dirk Zimoch
- Re: EPICS 7.0.1-pre1 (typeCast.h) Michael Davidsaver
- Re: EPICS 7.0.1-pre1 (typeCast.h) Dirk Zimoch
Re: EPICS 7.0.1-pre1 (pdbsingle.cpp) Dirk Zimoch
<2017>
2025
2026
Re: EPICS 7.0.1-pre1 (pdbsingle.cpp) Michael Davidsaver
<2017>
2025
2026
ANJ, 21 Dec 2017 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
