2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS 7 makeBaseApp
Date: Fri, 24 Nov 2017 22:46:12 +0000
Hi again,
correction: the groups did work in the IOC after all. I just did not pay attention first that the info tag syntax was the old one in the db I tried first. Sorry for the confusion.
Now groups work nicely, this is pretty cool :-)
Thus the only changes I had to do were to add
myiocname_LIBS += pvAccessIOC
to the IOC makefile and change the info tags to the new syntax where needed.
Timo
From: <[email protected]> on behalf of Timo Korhonen <[email protected]>
Date: Thursday 23 November 2017 at 14:22
Subject: EPICS 7 makeBaseApp
I could make a little progress with including qsrv in an IOC.
I am using the tarball base-7.0.1-pre1.
After compiling Base, I used makeBaseApp to create an ioc directory.
Following instructions in Michael's documentation, I added these to the Makefile:
# include QSRV
myiocname_DBD += PVAServerRegister.dbd
myiocname_DBD += qsrv.dbd
myiocname_LIBS += qsrv
Then the linker complained about missing functions "refTrackRegistrar" and "registerStartPVAServer".
After poking around a bit I added:
And then linking succeeded and qsrv started.
However, the groups did not work; they seem not to be created. Is there maybe a separate/new parser to handle the new info tags that I should link in?
In this process I tried the example IOCs in the pva2pva directory, using softIocPVA.
However, groups did not work in the circle and circle2 applications. In imagedemo the groups worked as (I) expected.
I did not go into finding out why, this was at home in the late evening...I may try more today.
One thing that I noticed is that pvlist works half way: it finds the IOC but does not give the channel list. The error message is
"failed to fetch channel list – not supported". Maybe qsrv does not have this feature yet? It used to work with procSrv.
Sorry for the poor formatting of these messages, I did this at home and my environment there is not primarily set up for EPICS development, at least yet;-)
Timo
Re: EPICS 7 makeBaseApp Michael Davidsaver
EPICS 7 makeBaseApp Timo Korhonen
Prev: Re: EPICS 7.0.1-pre1 Johnson, Andrew N.
Next: Re: EPICS 7 makeBaseApp Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS 7 makeBaseApp Timo Korhonen
