Hi Dirk,
As Michael said you need the recursive flag, the Jenkins git plugin has a check box for that. You should also use the git Advanced behaviors to clean the working tree, either before or after checkout. I’d be happy to share my Jenkins configurations if you want
to see them.
BTW we explicitly do not support VxWorks 5.x any more, the compilers are just too old, and your finding that some of the earlier 6.x compilers don’t work either doesn’t surprise me. It is not reasonable to expect developers to write new code against ancient
compilers.
- Andrew
Sent from my iPad
On 22.11.2017 16:47, Michael Davidsaver wrote:
Dirk,
Have you/PSI considered setting up a continuous integration builder as
APS has done? I would be far easier if we (Base developers) could have
quicker notice about build issues.
Michael
https://jenkins.aps.anl.gov/view/EPICS%20Base/
I am trying to set up a Jenkins server here. But when it builds EPICS, it only installs some scripts but does not compile any code. With the tar file it compiles. What is wrong? I use the core/master branch.
- Re: EPICS 7.0.1-pre1 Dirk Zimoch
- EPICS 7.0.1-pre1 Andrew Johnson
- Re: EPICS 7.0.1-pre1 Michael Davidsaver
Re: EPICS 7.0.1-pre1 Ralph Lange
Re: EPICS 7 makeBaseApp Timo Korhonen
<2017>
2025
2026
<2017>
2025
2026
ANJ, 21 Dec 2017 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
