2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS 7.0.1-pre1
To: "Johnson, Andrew N." <[email protected]>
Date: Mon, 27 Nov 2017 09:24:11 +0100
On 24.11.2017 20:02, Johnson, Andrew N. wrote:
Hi Dirk,
As Michael said you need the recursive flag, the Jenkins git plugin has
a check box for that. You should also use the git Advanced behaviors to
clean the working tree, either before or after checkout. I’d be happy to
share my Jenkins configurations if you want to see them.
I did not know about submodules. I will have a look at the Jenkins configuration.
BTW we explicitly do not support VxWorks 5.x any more, the compilers are
just too old, and your finding that some of the earlier 6.x compilers
don’t work either doesn’t surprise me. It is not reasonable to expect
developers to write new code against ancient compilers.
I do not expect EPICS 7 to compile with 5.5. But it surprised me that at the beginning even 6.7 did not work.
Maybe it is possible to use earlier compilers without PV access. Is there an option to skip PVA for some architectures but not for all?
E.g. WITHOUT_PVA=YES in CONFIG.Common.vxWorks6.2-ppc604
- Andrew
Sent from my iPad
On Nov 24, 2017, at 9:34 AM, Dirk Zimoch <[email protected]
<mailto:[email protected]>> wrote:
On 22.11.2017 16:47, Michael Davidsaver wrote:
Dirk,
Have you/PSI considered setting up a continuous integration builder as
APS has done?  I would be far easier if we (Base developers) could have
quicker notice about build issues.
Michael
https://jenkins.aps.anl.gov/view/EPICS%20Base/
I am trying to set up a Jenkins server here. But when it builds EPICS,
it only installs some scripts but does not compile any code. With the
tar file it compiles.  What is wrong? I use the core/master branch.
EPICS 7.0.1-pre1 Andrew Johnson
Re: EPICS 7.0.1-pre1 Dirk Zimoch
Re: EPICS 7.0.1-pre1 Michael Davidsaver
Re: EPICS 7.0.1-pre1 Johnson, Andrew N.
Prev: Re: EPICS 7.0.1-pre1 Heinz Junkes
Next: EPICS 7 not handling configuration errors Dirk Zimoch
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS 7.0.1-pre1 Johnson, Andrew N.
Next: Re: EPICS 7.0.1-pre1 (typeCast.h) Michael Davidsaver
