EPICS 7 could be more verbose in case of configuration errors.
If I try this:
make CROSS_COMPILER_TARGET_ARCHS=doesnotexist
I do not get an error message complaining about missing configuration
files for the "doesnotexist" architecture.
Instead I get:
make[4]: Entering directory
`/afs/psi.ch/group/8431/dirk/git/BASE/base-7.0.1-pre1/modules/libcom/src/O.doesnotexist'
perl -CSD ../../src/error/makeStatTbl.pl ../../src/osi/devLib.h
../../src/osi/epicsTime.h ../../src/as/asLib.h
../../src/misc/epicsStdlib.h ../../src/pool/epicsThreadPool.h
../../src/error/errMdef.h
perl -CSD ../../src/env/bldEnvData.pl -t doesnotexist \
-c gcc -s /usr/local/epics/base-7.0.1/configure
Usage: bldEnvData.pl [options] configure
-h Help: Print this message
-q Quiet: Only print errors
-o file Output filename, default is envData.c
-t arch Target architecture $(T_A) name
-s os Operating system $(OS_CLASS)
-c comp Compiler class $(CMPLR_CLASS)
/usr/local/epics/base-7.0.1/bin/RHEL7-x86_64/e_flex
-S/usr/local/epics/base-7.0.1/include/flex.skel.static -8 -I -t
../../src/as/asLib_lex.l > asLib_lex.yy.c
mv asLib_lex.yy.c asLib_lex.c
/usr/local/epics/base-7.0.1/bin/RHEL7-x86_64/antelope -basLib
../../src/as/asLib.y
mv asLib.tab.c asLib.c
make[4]: *** No rule to make target `../O.Common/osiFileName.h', needed
by `inc'. Stop.
Took me a while to find out that the error was a missing config file.
EPICS is more helpful if the host architecture configuration is missing:
make EPICS_HOST_ARCH=nosuchhost
configure/CONFIG:54: configure/os/CONFIG.nosuchhost.Common: No such file
or directory
make: *** No rule to make target
`configure/os/CONFIG.nosuchhost.Common'. Stop.
Not nice but points in the correct direction.
Dirk
Re: EPICS 7.0.1-pre1 Dirk Zimoch
Re: EPICS 7.0.1-pre1 (spinlock.hpp) Andrew Johnson
<2017>
2025
2026
Re: EPICS 7 makeBaseApp Michael Davidsaver
git question Dirk Zimoch
<2017>
2025
2026
