2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS 7.0.1-pre1 (dbJLinkInit: lexical error: invalid char in json text. ) on Fedora 26
From: "Williams Jr., Ernest L." <[email protected]>
To: Andrew Johnson <[email protected]>, EPICS core-talk <[email protected]>
Date: Tue, 28 Nov 2017 18:57:26 +0000
Ernest Williams
Dept. Head, Advanced Control Systems
Advanced Instrumentation Research, Technology Innovation Directorate
SLAC National Laboratory, Stanford University
Sent: Tuesday, November 28, 2017 9:50 AM
To: Williams Jr., Ernest L.; EPICS core-talk
Hi Ernest,
On 11/28/2017 09:56 AM, Williams Jr., Ernest L. wrote:
> All the tests pass successfully on our standard
> RHEL6 and RHEL7 machines at SLAC.
Great, thanks for taking the time to build this and run the tests.
> However, for Fedora 26 although all of the tests passed I see the following:
<snip>
These error messages are expected, they occur because we have tests to
check that our APIs properly flag error situations, and some of those
APIs also send error messages to stderr. The tests themselves are not
failing (they all say "ok"). We usually try to silence these messages
while running the individual test programs, but that isn't always
possible (or we just didn't get sufficiently annoyed by those particular
programs yet).
<ernest>
Sounds good.  Thanks 😊
- Andrew
>                                  {"x":bbbb}
>                     (right here) ------^
> dbJLinkInit: parse error: premature EOF
>                                       {"z":{"good":6}
> dbRegisterServer: 'one' registered twice?
> dbRegisterServer: Bad server name 'bad name'
> dbRegisterServer: Ignoring 'disabled', per environment
> dbUnregisterServer: Servers still active!
> dbUnregisterServer: 'toolate' not registered.
> dbUnregisterServer: 'no-routines' has no stop() method.
> chfConfigParseStart: plugin pvt alloc failed
> dbRegisterServer: 'rsrv' registered twice?
> dbConvertJSON: parse error: trailing garbage
>                                      0x10
>                                      0x10
>                                      0x10
>                                      0x10
>                                      0x10
>                                      0x10
>                                      0x10
>                                      0x10
EPICS 7.0.1-pre1 (dbJLinkInit: lexical error: invalid char in json text. ) on Fedora 26 Williams Jr., Ernest L.
Re: EPICS 7.0.1-pre1 (dbJLinkInit: lexical error: invalid char in json text. ) on Fedora 26 Andrew Johnson
Prev: Re: EPICS 7.0.1-pre1 (epicsException.h) Andrew Johnson
Next: Re: EPICS 7.0.1-pre1 (epicsException.h) Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS 7.0.1-pre1 (dbJLinkInit: lexical error: invalid char in json text. ) on Fedora 26 Andrew Johnson
Next: git problem Dirk Zimoch
