2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS 7.0.1-pre1 (epicsException.h)
To: Michael Davidsaver <[email protected]>, <[email protected]>
Date: Tue, 28 Nov 2017 12:45:25 -0600
On 11/28/2017 11:42 AM, Michael Davidsaver wrote:
> The virtual dtors for RefMonitor and ChannelProviderRegistry
> are simple fixes which don't need further review.
Should ChannelProviderRegistry::~ChannelProviderRegistry() be public or
private? The ctor is private to prevent sub-classing so I suspect the
dtor should be too, but Dirk made it public.
> The change to epicsException.h also seems straightforward, though I'd
> add parenthesis after 'defined'.
Okay.
> I don't like removing FORCE_INLINE from castUnsafe().  This needs
> further analysis and a more target fix.
> https://gcc.gnu.org/bugzilla/show_bug.cgi?id=54965
Awaiting your suggestions there then.
> As for the change to pva/client.h, it isn't clear to me from the diff
> just what is being changed (please use "diff -u"!).
The line numbers are a bit off against the master branch, probably
because of commit 250826ff which happened since his checkout. This is
the git diff against the current HEAD:
> diff --git a/src/client/pva/client.h b/src/client/pva/client.h
> index 08998b3..7721adb 100644
> --- a/src/client/pva/client.h
> +++ b/src/client/pva/client.h
> @@ -193,7 +193,11 @@ void registerRefTrack();
>  class epicsShareClass ClientChannel
> +#if defined __GNUC__ && __GNUC__*100+__GNUC_MINOR__ < 305
> +public:
> +#endif
>      struct Impl;
> +private:
>      std::tr1::shared_ptr<Impl> impl;
>      friend class ClientProvider;
>      friend void detail::registerRefTrack();
That looks a little strange, but could be a valid workaround to a gcc issue.
> I was expecting a change like this to pvif (in class FieldName), so
> I'm not clear what's going on here.
I don't see anything comparable in pvif.h.
- Andrew
Re: EPICS 7.0.1-pre1 (epicsException.h) Andrew Johnson
Re: EPICS 7.0.1-pre1 (epicsException.h) Michael Davidsaver
Re: EPICS 7.0.1-pre1 (epicsException.h) Dirk Zimoch
EPICS 7.0.1-pre1 Andrew Johnson
Re: EPICS 7.0.1-pre1 Dirk Zimoch
Prev: Re: EPICS 7.0.1-pre1 (dbJLinkInit: lexical error: invalid char in json text. ) on Fedora 26 Andrew Johnson
Next: Re: EPICS 7.0.1-pre1 (dbJLinkInit: lexical error: invalid char in json text. ) on Fedora 26 Williams Jr., Ernest L.
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS 7.0.1-pre1 (epicsException.h) Michael Davidsaver
Next: Re: EPICS 7.0.1-pre1 (epicsException.h) Andrew Johnson
