2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS 7.0.1-pre1 (epicsException.h)
To: Andrew Johnson <[email protected]>, [email protected]
Date: Tue, 28 Nov 2017 11:42:24 -0600
On 11/28/2017 11:23 AM, Andrew Johnson wrote:
> Michael,
> I will manually apply Dirk's (reversed) patch, do you want to review
> these as PRs (both pvDataCPP and pvAccessCPP are modified)?
The virtual dtors for RefMonitor and ChannelProviderRegistry are simple fixes which don't need further review.
The change to epicsException.h also seems straightforward, though I'd add parenthesis after 'defined'.
I don't like removing FORCE_INLINE from castUnsafe().  This needs further analysis and a more target fix.
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=54965
As for the change to pva/client.h, it isn't clear to me from the diff just what is being changed (please use "diff -u"!).
I was expecting a change like this to pvif (in class FieldName), so I'm not clear what's going on here.
> - Andrew
> On 11/28/2017 10:56 AM, Dirk Zimoch wrote:
>> I think the attached patch file solves it.
>> On 28.11.2017 17:53, Dirk Zimoch wrote:
>>> I am trying to get it done right now.
>>> But unfortunately after updating core/master, it does not compile any
>>> more for my host architecture.
>>> And the day end in 7 minutes.
>>> I probably send you a patch file instead of what I thinks should work.
>>> On 28.11.2017 17:49, Andrew Johnson wrote:
>>>> Hi Dirk,
>>>> Michael and I need to know exactly what changes you still need to be
>>>> committed for the VxWorks 6.3 and/or 6.7 builds that are not already in
>>>> our repositories. Posting the output from 'git diff' rather than just a
>>>> description like this is much better, it ensures we don't miss anything.
>>>> If you can do that TODAY we'd appreciate it, we're wanting to tag the
>>>> -rc1 release, and we'd prefer to have your changes included if possible.
>>>> Thanks,
>>>> - Andrew
>>>> On 11/28/2017 09:39 AM, Dirk Zimoch wrote:
>>>>> The __GNUC__ version of the macro SHOW_EXCEPTION from
>>>>> modules/pvData/src/misc/pv/epicsException.h crashes g++ version 3.4.4
>>>>> /afs/psi.ch/project/vxworks/WindRiverGPP3.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/../lib/gcc/powerpc-wrs-vxworks/3.4.4/../../../../include/c++/3.4.4/xstring:
>>>>> In function `void testLogicException()':
>>>>> /afs/psi.ch/project/vxworks/WindRiverGPP3.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/../lib/gcc/powerpc-wrs-vxworks/3.4.4/../../../../include/c++/3.4.4/xstring:78:
>>>>> internal compiler error: in expand_expr_real, at expr.c:8417
>>>>> Please submit a full bug report,
>>>>> with preprocessed source if appropriate.
>>>>> Contact [email protected] for instructions.
>>>>> This can be fixed by using the non-__GNUC__ version for __GNUC__ < 4
>>>>> #if !defined __GNUC__ || __GNUC__ < 4
>>>>> #  define SHOW_EXCEPTION(EI) ::epics::pvData::detail::showException(EI)
>>>>> With that change, I could finally build EPICS 7 for vxWorks 6.3.
>>>>> (Thus the boost header spinlock_pt.hpp is not obsolete.)
Re: EPICS 7.0.1-pre1 (epicsException.h) Andrew Johnson
EPICS 7.0.1-pre1 Andrew Johnson
Re: EPICS 7.0.1-pre1 Dirk Zimoch
Re: EPICS 7.0.1-pre1 (epicsException.h) Dirk Zimoch
Prev: Re: EPICS 7.0.1-pre1 (epicsException.h) Andrew Johnson
Next: Re: EPICS 7.0.1-pre1 (dbJLinkInit: lexical error: invalid char in json text. ) on Fedora 26 Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: EPICS 7.0.1-pre1 (epicsException.h) Andrew Johnson
