2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: more git problems
Date: Thu, 7 Dec 2017 17:42:20 +0100
I tried to do changes on modules/database
When I wanted to commit, I get the error that I am not on any branch.
Then I did
* git stash
* in the top level: git submodule update --remote
* back in modules/database: git co core/master
* git stash apply
Here I get the errors:
CONFLICT (delete/modify): src/std/dev/devMbbiDirectSoft.c deleted in Updated upstream and modified in Stashed changes. Version Stashed changes of src/std/dev/devMbbiDirectSoft.c left in tree.
... [for all my changes]
git status tells me:
# On branch core/master
# Unmerged paths:
#   (use "git reset HEAD <file>..." to unstage)
#   (use "git add/rm <file>..." as appropriate to mark resolution)
#       deleted by us:      ../../../src/std/dev/devMbbiDirectSoft.c
#       deleted by us:      ../../../src/std/dev/devMbbiDirectSoftCallback.c
#       deleted by us:      ../../../src/std/dev/devMbbiDirectSoftRaw.c
#       deleted by us:      ../../../src/std/dev/devMbboDirectSoft.c
#       deleted by us:      ../../../src/std/dev/devMbboDirectSoftCallback.c
#       deleted by us:      ../../../src/std/rec/mbbiDirectRecord.c
#       deleted by us:      ../../../src/std/rec/mbbiDirectRecord.dbd
#       deleted by us:      ../../../src/std/rec/mbboDirectRecord.c
#       deleted by us:      ../../../src/std/rec/mbboDirectRecord.dbd
#       deleted by us:      Makefile
My changes are seemingly gone (?) and the module is distressingly empty.
Wrong branch? Maybe.
git co database/master
error: Your local changes to the following files would be overwritten by checkout:
        configure/os/CONFIG_SITE.Common.vxWorksCommon
        configure/os/CONFIG_SITE.linux-x86.Common
        configure/os/CONFIG_SITE.linux-x86_64.Common
Please, commit your changes or stash them before you can switch branches.
Aborting
HELP!
Re: more git problems Dirk Zimoch
Re: more git problems Michael Davidsaver
Prev: Re: base-7.0, can't make on linux Andrew Johnson
Next: Re: more git problems Dirk Zimoch
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: base-7.0, can't make on linux Mark Rivers
