2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: base-7.0, can't make on linux
To: 'Heinz Junkes' <[email protected]>, EPICS core-talk <[email protected]>
Date: Thu, 7 Dec 2017 17:14:15 +0000
If you want to test the -rc1 tag in your git checkout then do the following at the top-level
git checkout R7.0.1-rc1
git submodule update
That will put all submodules in a detached HEAD state at the correct commit.
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of Heinz Junkes
> Sent: Thursday, December 07, 2017 10:27 AM
> To: EPICS core-talk
> Subject: base-7.0, can't make on linux
> I checked out the base-7.0:
> git clone --recursive -b core/master https://git.launchpad.net/epics-base base-7.0
> running “make” gives:
> make -C ./libcom install
> make[2]: Entering directory '/home/fel/EPICS/base-7.0/modules/libcom'
> configure/CONFIG:19: /configure/CONFIG: No such file or directory
> configure/RULES_TOP:2: /configure/RULES_TOP: No such file or directory
> make[2]: *** No rule to make target '/configure/RULES_TOP'.  Stop.
> make[2]: Leaving directory '/home/fel/EPICS/base-7.0/modules/libcom'
> ../configure/RULES_DIRS:84: recipe for target 'libcom.install' failed
> make[1]: *** [libcom.install] Error 2
> make[1]: Leaving directory '/home/fel/EPICS/base-7.0/modules'
> configure/RULES_DIRS:84: recipe for target 'modules.install' failed
> make: *** [modules.install] Error 2
> With the tar-file
> https://www.aps.anl.gov/epics/download/base/base-7.0.1-rc1.tar.gz
> everything works well.
> Heinz
base-7.0, can't make on linux Heinz Junkes
Prev: Re: more git problems Michael Davidsaver
Next: Jenkins build is back to normal : epics-master » linux64 #31 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: base-7.0, can't make on linux Andrew Johnson
Next: more git problems Dirk Zimoch
