2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: more git problems
To: Dirk Zimoch <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 7 Dec 2017 12:06:15 -0500
Dirk,
Calm down and don't delete anything.
Lets first focus on recovery to where you were previously.
When you run:
> gitk stash@{0}
You should see the revision which was checked out when you saved this stash.
Run
> git checkout -b <tempbranchname> <revision>
This will create a new/temporary branch at the base revision.
Now
> git submodule update
Which updates the sub-modules to be at the revision(s) when the super-module
commit was made.
Finally
> git stash apply
Which should succeed if everything is really back as it was (wrt. untracked files).
Michael
On 12/07/2017 11:51 AM, Dirk Zimoch wrote:
> So how can I check out the latest version from the server to apply my stash on?
> On 07.12.2017 17:49, Dirk Zimoch wrote:
>> On 07.12.2017 17:46, Michael Davidsaver wrote:
>>> On 12/07/2017 11:42 AM, Dirk Zimoch wrote:
>>>> My changes are seemingly gone (?) and the module is distressingly empty.
>>>> Wrong branch? Maybe.
>>> Your changes are not gone:
>>> Run
>>>> git stash list
>>> Your most recent stash is stash@{0}
>>> You can use
>>>> gitk stash@{0}
>>> which should show your changes, and which revision they were made
>>> against.
>> $ git stash list
>> stash@{0}: WIP on (no branch): f44bfd8 Install databaseModuleDirs.pm
>> into bin/<host>
Re: more git problems Zimoch Dirk (PSI)
more git problems Dirk Zimoch
Re: more git problems Michael Davidsaver
Re: more git problems Dirk Zimoch
Prev: Build failed in Jenkins: epics-master » linux32 #30 APS Jenkins
Next: RE: base-7.0, can't make on linux Mark Rivers
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: more git problems Dirk Zimoch
Next: Re: more git problems Zimoch Dirk (PSI)
