Hi Michael,
I will try that tomorrow when I‘m back at work.
Git drives me crazy.
Dirk,
Calm down and don't delete anything.
Lets first focus on recovery to where you were previously.
When you run:
gitk stash@{0}
You should see the revision which was checked out when you saved this stash.
Run
git checkout -b <tempbranchname> <revision>
This will create a new/temporary branch at the base revision.
Now
git submodule update
Which updates the sub-modules to be at the revision(s) when the super-module
commit was made.
Finally
git stash apply
Which should succeed if everything is really back as it was (wrt. untracked files).
Michael
On 12/07/2017 11:51 AM, Dirk Zimoch wrote:
So how can I check out the latest version from the server to apply my stash on?
On 07.12.2017 17:49, Dirk Zimoch wrote:
On 07.12.2017 17:46, Michael Davidsaver wrote:
On 12/07/2017 11:42 AM, Dirk Zimoch wrote:
My changes are seemingly gone (?) and the module is distressingly empty.
Wrong branch? Maybe.
Your changes are not gone:
Run
git stash list
Your most recent stash is stash@{0}
You can use
gitk stash@{0}
which should show your changes, and which revision they were made
against.
$ git stash list
stash@{0}: WIP on (no branch): f44bfd8 Install databaseModuleDirs.pm
into bin/<host>
- more git problems Dirk Zimoch
- Re: more git problems Michael Davidsaver
- Re: more git problems Dirk Zimoch
Jenkins build is back to normal : epics-master » linux32 #31 APS Jenkins
Re: base-7.0, can't make on linux Andrew Johnson
<2017>
2025
2026
Build failed in Jenkins: epics-master » mac #30 APS Jenkins
<2017>
2025
2026
ANJ, 21 Dec 2017 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
