2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: base-7.0, can't make on linux
To: <[email protected]>
Date: Thu, 7 Dec 2017 18:18:28 -0600
Finally fixed it everywhere (finding the Travis issue was really bad).
- Andrew
On 12/07/2017 10:33 AM, Andrew Johnson wrote:
> Hello Heinz,
> Yes, I broke it with a commit last night which I'm still in the process
> of fixing.
> - Andrew
> On 12/07/2017 10:26 AM, Heinz Junkes wrote:
>> I checked out the base-7.0:
>> git clone --recursive -b core/master https://git.launchpad.net/epics-base base-7.0
>> running “make” gives:
>> make -C ./libcom install
>> make[2]: Entering directory '/home/fel/EPICS/base-7.0/modules/libcom'
>> configure/CONFIG:19: /configure/CONFIG: No such file or directory
>> configure/RULES_TOP:2: /configure/RULES_TOP: No such file or directory
>> make[2]: *** No rule to make target '/configure/RULES_TOP'.  Stop.
>> make[2]: Leaving directory '/home/fel/EPICS/base-7.0/modules/libcom'
>> ../configure/RULES_DIRS:84: recipe for target 'libcom.install' failed
>> make[1]: *** [libcom.install] Error 2
>> make[1]: Leaving directory '/home/fel/EPICS/base-7.0/modules'
>> configure/RULES_DIRS:84: recipe for target 'modules.install' failed
>> make: *** [modules.install] Error 2
>> With the tar-file
>> https://www.aps.anl.gov/epics/download/base/base-7.0.1-rc1.tar.gz
>> everything works well.
>> Heinz
base-7.0, can't make on linux Heinz Junkes
Re: base-7.0, can't make on linux Andrew Johnson
Prev: Re: more git problems Zimoch Dirk (PSI)
Next: mbbioDirect 32 bit for EPICS 7 Dirk Zimoch
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: base-7.0, can't make on linux Andrew Johnson
Next: RE: base-7.0, can't make on linux Mark Rivers
