2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: moving initHooks into libCom
To: 'Andrew Johnson' <[email protected]>, 'Michael Davidsaver' <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 8 Dec 2017 21:03:14 +0000
The complete build of 7.0.1-rc1 was OK with that patch on:
VS2010
VS2015
VS2017
linux-x86_64
linux-x86
vxWorks-ppc604
> -----Original Message-----
> From: Andrew Johnson [mailto:[email protected]]
> Sent: Friday, December 08, 2017 2:51 PM
> To: Mark Rivers; 'Michael Davidsaver'; [email protected]
> Subject: Re: moving initHooks into libCom
> On 12/08/2017 02:48 PM, Mark Rivers wrote:
> > I have tested that fix on VS2015 and VS2017.  It fixes the problem.
> > I am now building all of R7.0.1-rc1 with that patch on 2010, 2015,
> > and 2017.
> Great!
> Michael, please push that commit to the master branch on github.
> - Andrew
> >> From: [email protected] [mailto:[email protected]] On
> Behalf
> >> Of Michael Davidsaver
> >> Sent: Friday, December 08, 2017 2:32 PM
> >> To: Andrew Johnson; [email protected]
> >> On 12/08/2017 03:29 PM, Andrew Johnson wrote:
> >>> Michael,
> >>> In case your Inbox filters out Jenkins emails the epics-master-windows
> >>> APS job is now demonstrating the pva2pva build failure.
> >> I noticed.  If this is the only failure, then I might have it sorted out quickly.
> https://github.com/mdavidsaver/pva2pva/commit/049ed8cead5e59dea7f6631698c45ea63db
> >> 78d66
> >>> Thanks,
> >>> - Andrew
> >>> On 12/08/2017 02:09 PM, Andrew Johnson wrote:
> >>>> On 12/08/2017 01:57 PM, Mark Rivers wrote:
> >>>>> I forget exactly what CALL does, but I don't think it's necessary.  It's
> >>>>> worth trying I guess.
> >>>> Yes, that fixed it. Jenkins runs build commands inside its own .BAT
> >>>> file, and apparently executing one .BAT file inside another stops the
> >>>> parent script. It's currently compiling using
> >>>>> Microsoft (R) C/C++ Optimizing Compiler Version 19.00.24215.1 for x64
> >>>> as against
> >>>>> Microsoft (R) C/C++ Optimizing Compiler Version 16.00.40219.01 for x64
> >>>>> Can you try the command interactively on that machine?
> >>>> I can't open a command window with the Jenkins build environment, the
> >>>> Jenkins agent sets up the shell environment by itself, and it's
> >>>> complicated by the fact that it's all running inside a JVM too.
> >>>> - Andrew
> Arguing for surveillance because you have nothing to hide is no
> different than making the claim, "I don't care about freedom of
> speech because I have nothing to say." -- Edward Snowdon
moving initHooks into libCom Michael Davidsaver
Re: moving initHooks into libCom Andrew Johnson
Re: moving initHooks into libCom Michael Davidsaver
RE: moving initHooks into libCom Mark Rivers
Prev: Re: moving initHooks into libCom Michael Davidsaver
Next: Jenkins build is back to normal : epics-master-windows » DLL,win32 #23 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: moving initHooks into libCom Andrew Johnson
Next: RE: moving initHooks into libCom Mark Rivers
