Hi Keenan,
I believe you were the last person to work on the iocsh scripting code
in Base, could you check whether your changes broke Mark's use case and
let us know what you discover please?
- Andrew
-------- Forwarded Message --------
Subject: Problem with iocsh output in 7.0.1?
Date: Fri, 15 Dec 2017 23:20:39 +0000
To: 'Andrew Johnson' <[email protected]>, EPICS core-talk
<[email protected]>
I have a vxWorks IOC startup script that mostly uses the VxWorks shell,
but switches to the iocsh shell for some commands. In 3.15.5 this works
fine, and I see the following:
value = 0 = 0x0
<SIS3820.cmd
# Example vxWorks startup file for SIS3820
iocsh
epics>
epics> epicsEnvSet("PREFIX", "13LAB:SIS3820:")
epics> epicsEnvSet("RNAME", "mca")
epics> epicsEnvSet("MAX_SIGNALS", "2")
epics> epicsEnvSet("MAX_CHANS", "10000")
epics> epicsEnvSet("EPICS_CA_MAX_ARRAY_BYTES", "500000")
epics> epicsEnvSet("PORT", "SIS3820/1")
epics> # For MCA records FIELD=READ, for waveform records FIELD=PROC
epics> epicsEnvSet("FIELD", "PROC")
epics>
epics> #drvSIS3820Config("Port name",
epics> # baseAddress,
epics> # interruptVector,
epics> # int interruptLevel,
epics> # channels,
epics> # signals,
epics> # use DMA
epics> # fifoBufferWords)
epics> drvSIS3820Config($(PORT), 0xA8000000, 224, 6, $(MAX_CHANS),
$(MAX_SIGNALS), 1, 0x20000)
epics>
epics> # This loads the scaler record and supporting records
epics> dbLoadRecords("$(STD)/stdApp/Db/scaler32.db", "P=13LAB:,
S=scaler3, DTYP=Asyn Scaler, OUT=@asyn($(PORT)), FREQ=50000000")
epics>
epics> # This database provides the support for the MCS functions
epics> dbLoadRecords("$(MCA)/mcaApp/Db/SIS38XX.template", "P=$(PREFIX),
PORT=$(PORT), SCALER=13LAB:scaler3")
epics>
epics> # Load either MCA or waveform records below
epics> # The number of records loaded must be the same as MAX_SIGNALS
defined above
epics>
epics> # Load the MCA records
epics> #dbLoadRecords("$(MCA)/mcaApp/Db/simple_mca.db", "P=$(PREFIX),
M=$(RNAME)1, DTYP=asynMCA, INP=@asyn($(PORT) 0), PREC=3,
CHANS=$(MAX_CHANS)")
M=$(RNAME)2, DTYP=asynMCA, INP=@asyn($(PORT) 1), PREC=3,
M=$(RNAME)3, DTYP=asynMCA, INP=@asyn($(PORT) 2), PREC=3,
M=$(RNAME)4, DTYP=asynMCA, INP=@asyn($(PORT) 3), PREC=3,
M=$(RNAME)5, DTYP=asynMCA, INP=@asyn($(PORT) 4), PREC=3,
M=$(RNAME)6, DTYP=asynMCA, INP=@asyn($(PORT) 5), PREC=3,
M=$(RNAME)7, DTYP=asynMCA, INP=@asyn($(PORT) 6), PREC=3,
M=$(RNAME)8, DTYP=asynMCA, INP=@asyn($(PORT) 7), PREC=3,
M=$(RNAME)9, DTYP=asynMCA, INP=@asyn($(PORT) 8), PREC=3,
M=$(RNAME)10, DTYP=asynMCA, INP=@asyn($(PORT) 9), PREC=3,
M=$(RNAME)11, DTYP=asynMCA, INP=@asyn($(PORT) 10), PREC=3,
M=$(RNAME)12, DTYP=asynMCA, INP=@asyn($(PORT) 11), PREC=3,
M=$(RNAME)13, DTYP=asynMCA, INP=@asyn($(PORT) 12), PREC=3,
M=$(RNAME)14, DTYP=asynMCA, INP=@asyn($(PORT) 13), PREC=3,
M=$(RNAME)15, DTYP=asynMCA, INP=@asyn($(PORT) 14), PREC=3,
M=$(RNAME)16, DTYP=asynMCA, INP=@asyn($(PORT) 15), PREC=3,
M=$(RNAME)17, DTYP=asynMCA, INP=@asyn($(PORT) 16), PREC=3,
M=$(RNAME)18, DTYP=asynMCA, INP=@asyn($(PORT) 17), PREC=3,
M=$(RNAME)19, DTYP=asynMCA, INP=@asyn($(PORT) 18), PREC=3,
M=$(RNAME)20, DTYP=asynMCA, INP=@asyn($(PORT) 19), PREC=3,
M=$(RNAME)21, DTYP=asynMCA, INP=@asyn($(PORT) 20), PREC=3,
M=$(RNAME)22, DTYP=asynMCA, INP=@asyn($(PORT) 21), PREC=3,
M=$(RNAME)23, DTYP=asynMCA, INP=@asyn($(PORT) 22), PREC=3,
M=$(RNAME)24, DTYP=asynMCA, INP=@asyn($(PORT) 23), PREC=3,
M=$(RNAME)25, DTYP=asynMCA, INP=@asyn($(PORT) 24), PREC=3,
M=$(RNAME)26, DTYP=asynMCA, INP=@asyn($(PORT) 25), PREC=3,
M=$(RNAME)27, DTYP=asynMCA, INP=@asyn($(PORT) 26), PREC=3,
M=$(RNAME)28, DTYP=asynMCA, INP=@asyn($(PORT) 27), PREC=3,
M=$(RNAME)29, DTYP=asynMCA, INP=@asyn($(PORT) 28), PREC=3,
M=$(RNAME)30, DTYP=asynMCA, INP=@asyn($(PORT) 29), PREC=3,
M=$(RNAME)31, DTYP=asynMCA, INP=@asyn($(PORT) 30), PREC=3,
M=$(RNAME)32, DTYP=asynMCA, INP=@asyn($(PORT) 31), PREC=3,
epics>
epics> # This loads the waveform records
epics> dbLoadRecords("$(MCA)/mcaApp/Db/SIS38XX_waveform.template",
"P=$(PREFIX), R=$(RNAME)1, INP=@asyn($(PORT) 0), CHANS=$(MAX_CHANS)")
"P=$(PREFIX), R=$(RNAME)2, INP=@asyn($(PORT) 1), CHANS=$(MAX_CHANS)")
epics> #dbLoadRecords("$(MCA)/mcaApp/Db/SIS38XX_waveform.template",
"P=$(PREFIX), R=$(RNAME)3, INP=@asyn($(PORT) 2), CHANS=$(MAX_CHANS)")
"P=$(PREFIX), R=$(RNAME)4, INP=@asyn($(PORT) 3), CHANS=$(MAX_CHANS)")
"P=$(PREFIX), R=$(RNAME)5, INP=@asyn($(PORT) 4), CHANS=$(MAX_CHANS)")
"P=$(PREFIX), R=$(RNAME)6, INP=@asyn($(PORT) 5), CHANS=$(MAX_CHANS)")
"P=$(PREFIX), R=$(RNAME)7, INP=@asyn($(PORT) 6), CHANS=$(MAX_CHANS)")
"P=$(PREFIX), R=$(RNAME)8, INP=@asyn($(PORT) 7), CHANS=$(MAX_CHANS)")
"P=$(PREFIX), R=$(RNAME)9, INP=@asyn($(PORT) 8), CHANS=$(MAX_CHANS)")
"P=$(PREFIX), R=$(RNAME)10, INP=@asyn($(PORT) 9), CHANS=$(MAX_CHANS)")
"P=$(PREFIX), R=$(RNAME)11, INP=@asyn($(PORT) 10), CHANS=$(MAX_CHANS)")
"P=$(PREFIX), R=$(RNAME)12, INP=@asyn($(PORT) 11), CHANS=$(MAX_CHANS)")
"P=$(PREFIX), R=$(RNAME)13, INP=@asyn($(PORT) 12), CHANS=$(MAX_CHANS)")
"P=$(PREFIX), R=$(RNAME)14, INP=@asyn($(PORT) 13), CHANS=$(MAX_CHANS)")
"P=$(PREFIX), R=$(RNAME)15, INP=@asyn($(PORT) 14), CHANS=$(MAX_CHANS)")
"P=$(PREFIX), R=$(RNAME)16, INP=@asyn($(PORT) 15), CHANS=$(MAX_CHANS)")
"P=$(PREFIX), R=$(RNAME)17, INP=@asyn($(PORT) 16), CHANS=$(MAX_CHANS)")
"P=$(PREFIX), R=$(RNAME)18, INP=@asyn($(PORT) 17), CHANS=$(MAX_CHANS)")
"P=$(PREFIX), R=$(RNAME)19, INP=@asyn($(PORT) 18), CHANS=$(MAX_CHANS)")
"P=$(PREFIX), R=$(RNAME)20, INP=@asyn($(PORT) 19), CHANS=$(MAX_CHANS)")
"P=$(PREFIX), R=$(RNAME)21, INP=@asyn($(PORT) 20), CHANS=$(MAX_CHANS)")
"P=$(PREFIX), R=$(RNAME)22, INP=@asyn($(PORT) 21), CHANS=$(MAX_CHANS)")
"P=$(PREFIX), R=$(RNAME)23, INP=@asyn($(PORT) 22), CHANS=$(MAX_CHANS)")
"P=$(PREFIX), R=$(RNAME)24, INP=@asyn($(PORT) 23), CHANS=$(MAX_CHANS)")
"P=$(PREFIX), R=$(RNAME)25, INP=@asyn($(PORT) 24), CHANS=$(MAX_CHANS)")
"P=$(PREFIX), R=$(RNAME)26, INP=@asyn($(PORT) 25), CHANS=$(MAX_CHANS)")
"P=$(PREFIX), R=$(RNAME)27, INP=@asyn($(PORT) 26), CHANS=$(MAX_CHANS)")
"P=$(PREFIX), R=$(RNAME)28, INP=@asyn($(PORT) 27), CHANS=$(MAX_CHANS)")
"P=$(PREFIX), R=$(RNAME)29, INP=@asyn($(PORT) 28), CHANS=$(MAX_CHANS)")
"P=$(PREFIX), R=$(RNAME)30, INP=@asyn($(PORT) 20), CHANS=$(MAX_CHANS)")
"P=$(PREFIX), R=$(RNAME)31, INP=@asyn($(PORT) 30), CHANS=$(MAX_CHANS)")
"P=$(PREFIX), R=$(RNAME)32, INP=@asyn($(PORT) 31), CHANS=$(MAX_CHANS)")
epics>
epics> asynSetTraceIOMask($(PORT),0,2)
epics> #asynSetTraceMask("$(PORT)",0,0xff)
epics>
epics> # Exit iocsh
epics> exit
value = 0 = 0x0
However, when I boot the same IOC in 7.0.1 I see this:
value = 0 = 0x0
<SIS3820.cmd
iocsh
epics> epics> epics> epics> epics> epics> epics> epics> epics> epics>
epics> epics> epics> epic s> epics> epics> epics>
e pics> epics> epics> epics> epics> epics> epics>
epics> epics> epics> epics> epics> epics> epics >
epics> epics> epics> ep ics> epics> epics> epics>
epics> epics> epics> epics> value = 0 = 0x0
So the iocsh commands are not echoed, I only see the epics> prompt, not
the command that is being executed. This seems like an undesirable
change in behavior?
- Re: Problem with iocsh output in 7.0.1? Lang, Keenan C.
- Problem with iocsh output in 7.0.1? Mark Rivers
PSI Jenkins Dirk Zimoch
<2017>
2025
2026
<2017>
2025
2026
