2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem building example application on windows-x64
To: Andrew Johnson <[email protected]>, [email protected]
Date: Wed, 27 Dec 2017 13:08:11 -0600
On 12/27/2017 01:04 PM, Andrew Johnson wrote:
> Michael: How about we drop the seconds field completely from the build
> date/time-stamp? That should prevent this kind of problem from
> recurring. It would still trigger a re-creation of the header whenever
> there is a roll-over, but that should only happen once, not continuously
> like Mark is seeing.
Sure.  The timestamp is meant as a fallback when neither an developer
provided version number, nor VCS information, is available.
Problem building example application on windows-x64 Mark Rivers
RE: Problem building example application on windows-x64 Mark Rivers
Re: Problem building example application on windows-x64 Andrew Johnson
Prev: Re: Problem building example application on windows-x64 Andrew Johnson
Next: New full-text RSS feeds now available Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Problem building example application on windows-x64 Mark Rivers
ANJ, 27 Dec 2017 · Home · News · About · Talk · Base · Modules · Extensions ·
