2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: "DSO missing" errors for missing intermediate dependencies
To: EPICS Core Talk <[email protected]>
Date: Thu, 11 Jan 2018 11:16:15 +0100
Dear core-talkers,
Moving from RHEL6 to RHEL7, we ran into the issue that with the newer system the linker line for an executable has to mention all intermediate dependencies, while on RHEL6 is was good enough that intermediate dependency libraries were mentioned in the internal dependency list (output of 'ldd') of a primary dependency library.
As a result of the missing intermediate dependency, you get error messages like
    /usr/bin/ld: PIDThread.o: undefined reference to symbol 'pthread_create@@GLIBC_2.2.5'
    /usr/lib64/libpthread.so.0: error adding symbols: DSO missing from command line
At first glance, the setting of POSIX_LDLIBS (in CONFIG.Common.linuxCommon) seems to try to avoid this for pthreads, but it turns out that this is added only (in CONFIG.Common.UnixCommon) for STATIC_BUILD = YES or SHARED_LIBRARIES = NO.
How should we address this?
Cheers,
~Ralph
Re: "DSO missing" errors for missing intermediate dependencies Andrew Johnson
Prev: Re: Removal of deprecated in pvDataCPP/pvAccessCPP Michael Davidsaver
Next: Re: "DSO missing" errors for missing intermediate dependencies Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 11 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
