2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.14-win64 #233
To: [email protected]
Date: Fri, 19 Jan 2018 00:29:29 -0600 (CST)
See <https://jenkins.aps.anl.gov/job/epics-base-3.14-win64/233/display/redirect>
[...truncated 5.70 KB...]
Removing include/epicsSingleton.h
Removing include/epicsStdio.h
Removing include/epicsStdioRedirect.h
Removing include/epicsStdlib.h
Removing include/epicsString.h
Removing include/epicsThread.h
Removing include/epicsTime.h
Removing include/epicsTimer.h
Removing include/epicsTypes.h
Removing include/epicsUnitTest.h
Removing include/epicsVersion.h
Removing include/errlog.h
Removing include/errMdef.h
Removing include/error.h
Removing include/errSymTbl.h
Removing include/eventRecord.h
Removing include/fanoutRecord.h
Removing include/fdManager.h
Removing include/fdmgr.h
Removing include/flex.skel.static
Removing include/freeList.h
Removing include/gdd.h
Removing include/gddAppFuncTable.h
Removing include/gddApps.h
Removing include/gddAppTable.h
Removing include/gddArray.h
Removing include/gddArrayI.h
Removing include/gddContainer.h
Removing include/gddContainerI.h
Removing include/gddEnumStringTable.h
Removing include/gddErrorCodes.h
Removing include/gddI.h
Removing include/gddNewDel.h
Removing include/gddScalar.h
Removing include/gddScalarI.h
Removing include/gddUtils.h
Removing include/gddUtilsI.h
Removing include/generalTimeSup.h
Removing include/gpHash.h
Removing include/guigroup.h
Removing include/histogramRecord.h
Removing include/initHooks.h
Removing include/iocInit.h
Removing include/iocLog.h
Removing include/iocsh.h
Removing include/iocshRegisterCommon.h
Removing include/ipAddrToAsciiAsynchronous.h
Removing include/libComRegister.h
Removing include/link.h
Removing include/locationException.h
Removing include/logClient.h
Removing include/longinRecord.h
Removing include/longoutRecord.h
Removing include/macLib.h
Removing include/mbbiDirectRecord.h
Removing include/mbbiRecord.h
Removing include/mbboDirectRecord.h
Removing include/mbboRecord.h
Removing include/menuAlarmSevr.h
Removing include/menuAlarmStat.h
Removing include/menuCompress.h
Removing include/menuConvert.h
Removing include/menuFtype.h
Removing include/menuIvoa.h
Removing include/menuOmsl.h
Removing include/menuPini.h
Removing include/menuPriority.h
Removing include/menuScan.h
Removing include/menuSimm.h
Removing include/menuYesNo.h
Removing include/miscIocRegister.h
Removing include/osiClockTime.h
Removing include/osiPoolStatus.h
Removing include/osiProcess.h
Removing include/osiSock.h
Removing include/osiWireFormat.h
Removing include/permissiveRecord.h
Removing include/postfix.h
Removing include/recGbl.h
Removing include/recSup.h
Removing include/registry.h
Removing include/registryCommon.h
Removing include/registryDeviceSupport.h
Removing include/registryDriverSupport.h
Removing include/registryFunction.h
Removing include/registryIocRegister.h
Removing include/registryRecordType.h
Removing include/resourceLib.h
Removing include/rsrv.h
Removing include/rsrvIocRegister.h
Removing include/selRecord.h
Removing include/seqRecord.h
Removing include/shareLib.h
Removing include/smartGDDPointer.h
Removing include/special.h
Removing include/stateRecord.h
Removing include/stringinRecord.h
Removing include/stringoutRecord.h
Removing include/subArrayRecord.h
Removing include/subRecord.h
Removing include/taskwd.h
Removing include/testMain.h
Removing include/tsBTree.h
Removing include/tsDefs.h
Removing include/tsDLList.h
Removing include/tsFreeList.h
Removing include/tsMinMax.h
Removing include/tsSLList.h
Removing include/unixFileName.h
Removing include/waveformRecord.h
Removing lib/
Removing src/RTEMS/base/O.Common/
Removing src/RTEMS/base/O.windows-x64-static/
Removing src/RTEMS/base/O.windows-x64/
Removing src/as/O.Common/
Removing src/as/O.windows-x64-static/
Removing src/as/O.windows-x64/
Removing src/bpt/O.Common/
Removing src/bpt/O.windows-x64-static/
Removing src/bpt/O.windows-x64/
Removing src/ca/O.Common/
Removing src/ca/O.windows-x64-static/
Removing src/ca/O.windows-x64/
Removing src/cap5/O.Common/
Removing src/cap5/O.windows-x64-static/
Removing src/cap5/O.windows-x64/
Removing src/cas/build/O.Common/
Removing src/cas/build/O.windows-x64-static/
Removing src/cas/build/O.windows-x64/
Removing src/cas/example/directoryService/O.Common/
Removing src/cas/example/directoryService/O.windows-x64-static/
Removing src/cas/example/directoryService/O.windows-x64/
Removing src/catools/O.Common/
Removing src/catools/O.windows-x64-static/
Removing src/catools/O.windows-x64/
Removing src/db/O.Common/
Removing src/db/O.windows-x64-static/
Removing src/db/O.windows-x64/
Removing src/db/test/O.Common/
Removing src/db/test/O.windows-x64-static/
Removing src/db/test/O.windows-x64/
Removing src/dbStatic/O.Common/
Removing src/dbStatic/O.windows-x64-static/
Removing src/dbStatic/O.windows-x64/
Removing src/dbtools/O.Common/
Removing src/dbtools/O.windows-x64-static/
Removing src/dbtools/O.windows-x64/
Removing src/dev/softDev/O.Common/
Removing src/dev/softDev/O.windows-x64-static/
Removing src/dev/softDev/O.windows-x64/
Removing src/dev/testDev/O.Common/
Removing src/dev/testDev/O.windows-x64-static/
Removing src/dev/testDev/O.windows-x64/
Removing src/excas/O.Common/
Removing src/excas/O.windows-x64-static/
Removing src/excas/O.windows-x64/
Removing src/gdd/O.Common/
Removing src/gdd/O.windows-x64-static/
Removing src/gdd/O.windows-x64/
Removing src/libCom/O.Common/
Removing src/libCom/O.windows-x64-static/
Removing src/libCom/O.windows-x64/
Removing src/libCom/test/O.Common/
Removing src/libCom/test/O.windows-x64-static/
Removing src/libCom/test/O.windows-x64/
Removing src/makeBaseApp/O.Common/
Removing src/makeBaseApp/O.windows-x64-static/
Removing src/makeBaseApp/O.windows-x64/
Removing src/makeBaseExt/O.Common/
Removing src/makeBaseExt/O.windows-x64-static/
Removing src/makeBaseExt/O.windows-x64/
Removing src/misc/O.Common/
Removing src/misc/O.windows-x64-static/
Removing src/misc/O.windows-x64/
Removing src/rec/O.Common/
Removing src/rec/O.windows-x64-static/
Removing src/rec/O.windows-x64/
Removing src/registry/O.Common/
Removing src/registry/O.windows-x64-static/
Removing src/registry/O.windows-x64/
Removing src/rsrv/O.Common/
Removing src/rsrv/O.windows-x64-static/
Removing src/rsrv/O.windows-x64/
Removing src/softIoc/O.Common/
Removing src/softIoc/O.windows-x64-static/
Removing src/softIoc/O.windows-x64/
Removing src/tools/O.Common/
Removing src/tools/O.windows-x64-static/
Removing src/tools/O.windows-x64/
Removing src/toolsComm/antelope/O.Common/
Removing src/toolsComm/antelope/O.windows-x64-static/
Removing src/toolsComm/antelope/O.windows-x64/
Removing src/toolsComm/flex/O.Common/
Removing src/toolsComm/flex/O.windows-x64-static/
Removing src/toolsComm/flex/O.windows-x64/
Removing src/util/O.Common/
Removing src/util/O.windows-x64-static/
Removing src/util/O.windows-x64/
Removing src/vxWorks/O.Common/
Removing src/vxWorks/O.windows-x64-static/
Removing src/vxWorks/O.windows-x64/
Removing templates/
stderr: warning: failed to remove include/os
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:1970)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:1938)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:1934)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:1572)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:1584)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.clean(CliGitAPIImpl.java:762)
	at hudson.plugins.git.GitAPI.clean(GitAPI.java:311)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at hudson.remoting.RemoteInvocationHandler$RPCRequest.perform(RemoteInvocationHandler.java:922)
	at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:896)
	at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:853)
	at hudson.remoting.UserRequest.perform(UserRequest.java:207)
	at hudson.remoting.UserRequest.perform(UserRequest.java:53)
	at hudson.remoting.Request$2.run(Request.java:358)
	at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
	at java.util.concurrent.FutureTask.run(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at java.lang.Thread.run(Unknown Source)
	Suppressed: hudson.remoting.Channel$CallSiteStackTrace: Remote call to win64-1
		at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1693)
		at hudson.remoting.UserResponse.retrieve(UserRequest.java:310)
		at hudson.remoting.Channel.call(Channel.java:908)
		at hudson.remoting.RemoteInvocationHandler.invoke(RemoteInvocationHandler.java:281)
		at com.sun.proxy.$Proxy99.clean(Unknown Source)
		at org.jenkinsci.plugins.gitclient.RemoteGitImpl.clean(RemoteGitImpl.java:450)
		at hudson.plugins.git.extensions.impl.CleanBeforeCheckout.decorateFetchCommand(CleanBeforeCheckout.java:30)
		at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:821)
		at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1092)
		at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1123)
		at hudson.scm.SCM.checkout(SCM.java:495)
		at hudson.model.AbstractProject.checkout(AbstractProject.java:1202)
		at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:574)
		at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
		at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:499)
		at hudson.model.Run.execute(Run.java:1724)
		at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
		at hudson.model.ResourceController.execute(ResourceController.java:97)
		at hudson.model.Executor.run(Executor.java:421)
ERROR: Error fetching remote repo 'origin'
[WARNINGS] Skipping publisher since build result is FAILURE
Jenkins build is back to normal : epics-base-3.14-win64 #234 APS Jenkins
Prev: Build failed in Jenkins: epics-base-3.14-win32 #263 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.16-mac-test #178 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-base-3.14-win32 #264 APS Jenkins
Next: Jenkins build is back to normal : epics-base-3.14-win64 #234 APS Jenkins
ANJ, 19 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
