2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.14-test #26
To: [email protected]
Date: Thu, 1 Feb 2018 12:29:07 -0600 (CST)
See <https://jenkins.aps.anl.gov/job/epics-base-3.14-test/26/display/redirect>
[...truncated 801 B...]
+ make -s clean-tests CROSS_COMPILER_TARGET_ARCHS=
+ make -j4 --no-print-directory junitfiles CROSS_COMPILER_TARGET_ARCHS=
make -C ./configure junitfiles
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 junitfiles
make[2]: Nothing to be done for 'junitfiles'.
make -C ./src junitfiles
make -C ./tools junitfiles
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[3]: Nothing to be done for 'junitfiles'.
make -C ./makeBaseApp junitfiles
make -C ./makeBaseExt junitfiles
make -C ./libCom junitfiles
make -C ./toolsComm junitfiles
make -C ./ca junitfiles
make -C ./RTEMS junitfiles
make -C ./base junitfiles
make -C ./antelope junitfiles
make -C O.linux-x86_64 -f ../Makefile TOP=../../../.. \
make -C ./util junitfiles
make -C ./gdd junitfiles
make[4]: Nothing to be done for 'junitfiles'.
make -C ./flex junitfiles
make -C libCom/test junitfiles
make -C ./dbStatic junitfiles
perl epicsUnitTestTest.t -tap > epicsUnitTestTest.tap
perl epicsCalcTest.t -tap > epicsCalcTest.tap
perl epicsAlgorithmTest.t -tap > epicsAlgorithmTest.tap
perl epicsMathTest.t -tap > epicsMathTest.tap
perl epicsEllTest.t -tap > epicsEllTest.tap
perl epicsEnvTest.t -tap > epicsEnvTest.tap
perl epicsErrlogTest.t -tap > epicsErrlogTest.tap
perl epicsStdioTest.t -tap > epicsStdioTest.tap
perl epicsSockResolveTest.t -tap > epicsSockResolveTest.tap
make -C ./registry junitfiles
perl epicsStringTest.t -tap > epicsStringTest.tap
perl epicsTimeTest.t -tap > epicsTimeTest.tap
perl epicsTimeZoneTest.t -tap > epicsTimeZoneTest.tap
perl epicsThreadTest.t -tap > epicsThreadTest.tap
make -C ./bpt junitfiles
perl epicsThreadOnceTest.t -tap > epicsThreadOnceTest.tap
Recursive epicsThreadOnce() initialization
Thread recurse (0x25cf840) can't proceed, suspending.
make -C ./catools junitfiles
make -C ./cas junitfiles
make -C ./build junitfiles
make -C ./example junitfiles
make -C ./directoryService junitfiles
make -C O.linux-x86_64 -f ../Makefile TOP=../../../../.. \
make[5]: Nothing to be done for 'junitfiles'.
make -C ./cap5 junitfiles
perl epicsThreadPriorityTest.t -tap > epicsThreadPriorityTest.tap
perl epicsThreadPrivateTest.t -tap > epicsThreadPrivateTest.tap
perl epicsExitTest.t -tap > epicsExitTest.tap
perl epicsTimerTest.t -tap > epicsTimerTest.tap
perl ringPointerTest.t -tap > ringPointerTest.tap
perl ringBytesTest.t -tap > ringBytesTest.tap
perl epicsEventTest.t -tap > epicsEventTest.tap
perl epicsMutexTest.t -tap > epicsMutexTest.tap
perl macEnvExpandTest.t -tap > macEnvExpandTest.tap
macLib: macro FOO is undefined (expanding string ${FOO})
macLib: macro FOO is undefined (expanding string ${FOO,BAR})
macLib: macro FOO is undefined (expanding string ${FOO,BAR=baz})
macLib: macro FOO is undefined (expanding string ${FOO,BAR=$(FOO)})
macLib: macro FOO is undefined (expanding string ${FOO,FOO})
macLib: string ${FOO,FOO=$(FOO)} is recursive (expanding macro FOO)
macLib: macro FOO is undefined (expanding string ${FOO,BAR=baz,FUM})
macLib: macro BAZ is undefined (expanding string ${FOO})
macLib: string ${FOO} is recursive (expanding environment variable FOO)
macLib: string ${FOO,FOO=$(FOO)} is recursive (expanding environment variable FOO)
perl macLibTest.t -tap > macLibTest.tap
perl taskwdTest.t -tap > taskwdTest.tap
Thread testTask2 (0x6f0690) suspended
perl blockingSockTest.t -tap > blockingSockTest.tap
perl epicsMessageQueueTest.t -tap > epicsMessageQueueTest.tap
perl ipAddrToAsciiTest.t -tap > ipAddrToAsciiTest.tap
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsUnitTestTest.xml --input epicsUnitTestTest.tap epicsUnitTestTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsCalcTest.xml --input epicsCalcTest.tap epicsCalcTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsAlgorithmTest.xml --input epicsAlgorithmTest.tap epicsAlgorithmTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsMathTest.xml --input epicsMathTest.tap epicsMathTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsEllTest.xml --input epicsEllTest.tap epicsEllTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsEnvTest.xml --input epicsEnvTest.tap epicsEnvTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsErrlogTest.xml --input epicsErrlogTest.tap epicsErrlogTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsStdioTest.xml --input epicsStdioTest.tap epicsStdioTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsSockResolveTest.xml --input epicsSockResolveTest.tap epicsSockResolveTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsStringTest.xml --input epicsStringTest.tap epicsStringTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsTimeTest.xml --input epicsTimeTest.tap epicsTimeTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsTimeZoneTest.xml --input epicsTimeZoneTest.tap epicsTimeZoneTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsThreadTest.xml --input epicsThreadTest.tap epicsThreadTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsThreadOnceTest.xml --input epicsThreadOnceTest.tap epicsThreadOnceTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsThreadPriorityTest.xml --input epicsThreadPriorityTest.tap epicsThreadPriorityTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsThreadPrivateTest.xml --input epicsThreadPrivateTest.tap epicsThreadPrivateTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsExitTest.xml --input epicsExitTest.tap epicsExitTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsTimerTest.xml --input epicsTimerTest.tap epicsTimerTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output ringPointerTest.xml --input ringPointerTest.tap ringPointerTest
make -C ./db junitfiles
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output ringBytesTest.xml --input ringBytesTest.tap ringBytesTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsEventTest.xml --input epicsEventTest.tap epicsEventTest
make -C ./as junitfiles
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsMutexTest.xml --input epicsMutexTest.tap epicsMutexTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output macEnvExpandTest.xml --input macEnvExpandTest.tap macEnvExpandTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output macLibTest.xml --input macLibTest.tap macLibTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output taskwdTest.xml --input taskwdTest.tap taskwdTest
make -C ./dbtools junitfiles
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output blockingSockTest.xml --input blockingSockTest.tap blockingSockTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output ipAddrToAsciiTest.xml --input ipAddrToAsciiTest.tap ipAddrToAsciiTest
make -C ./rsrv junitfiles
make -C ./rec junitfiles
make -C db/test junitfiles
make -C ./excas junitfiles
perl callbackTest.t -tap > callbackTest.tap
make -C ./misc junitfiles
make -C ./dev junitfiles
make -C ./vxWorks junitfiles
make -C ./softDev junitfiles
make -C ./testDev junitfiles
make -C ./softIoc junitfiles
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output callbackTest.xml --input callbackTest.tap callbackTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsMessageQueueTest.xml --input epicsMessageQueueTest.tap epicsMessageQueueTest
+ make -s test-results CROSS_COMPILER_TARGET_ARCHS=
epicsUnitTestTest.tap ........ ok
epicsCalcTest.tap ............ ok
epicsAlgorithmTest.tap ....... ok
epicsMathTest.tap ............ ok
epicsEllTest.tap ............. ok
epicsEnvTest.tap ............. ok
epicsErrlogTest.tap .......... ok
epicsStdioTest.tap ........... ok
epicsSockResolveTest.tap ..... ok
epicsStringTest.tap .......... ok
epicsTimeTest.tap ............ ok
epicsTimeZoneTest.tap ........ ok
epicsThreadTest.tap .......... ok
epicsThreadOnceTest.tap ...... ok
epicsThreadPriorityTest.tap .. ok
epicsThreadPrivateTest.tap ... ok
epicsExitTest.tap ............ ok
epicsTimerTest.tap ...........
not ok  4 - percentError < messageThresh
Failed 1/41 subtests
ringPointerTest.tap .......... ok
ringBytesTest.tap ............ ok
epicsEventTest.tap ........... ok
epicsMutexTest.tap ........... ok
macEnvExpandTest.tap ......... ok
macLibTest.tap ............... ok
taskwdTest.tap ............... ok
blockingSockTest.tap ......... ok
epicsMessageQueueTest.tap .... ok
ipAddrToAsciiTest.tap ........ ok
Test Summary Report
epicsTimerTest.tap         (Wstat: 0 Tests: 41 Failed: 1)
  Failed test:  4
Files=28, Tests=2298,  0 wallclock secs ( 0.29 usr  0.04 sys +  0.01 cusr  0.03 csys =  0.37 CPU)
Result: FAIL
../../../../configure/RULES_BUILD:360: recipe for target 'test-results' failed
make[3]: *** [test-results] Error 1
../../../configure/RULES_ARCHS:61: recipe for target 'test-results.linux-x86_64' failed
make[2]: *** [test-results.linux-x86_64] Error 2
../configure/RULES_DIRS:83: recipe for target 'libCom/test.test-results' failed
make[1]: *** [libCom/test.test-results] Error 2
configure/RULES_DIRS:83: recipe for target 'src.test-results' failed
make: *** [src.test-results] Error 2
Build step 'Execute shell' marked build as failure
Recording test results
Jenkins build is back to normal : epics-base-3.14-test #27 APS Jenkins
Prev: P4P release prep Michael Davidsaver
Next: Jenkins build is back to normal : epics-base-3.14-test #27 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: P4P release prep Williams Jr., Ernest L.
ANJ, 05 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
