See <https://jenkins.aps.anl.gov/job/epics-master/OS=mac/42/display/redirect?page=changes>
Changes:
[Andrew Johnson] Fix slow callback test failures.
[Andrew Johnson] Configure command-line interface for VxWorks
[Andrew Johnson] Cleanup epicsReadline.c
[Andrew Johnson] Describe recent 3.16-only fixes in Release Notes
[Andrew Johnson] Add soft-channel tests for local dbCa links, both input and output
[Andrew Johnson] Updated links to new EPICS website at Argonne
[Andrew Johnson] Revert "tools: Use Carp"
[Andrew Johnson] tools: Add some context to the 'Undefined macro' warning
[Andrew Johnson] rec/test: Add missing filename to DBDDEPENDS_FILES
[Andrew Johnson] Config fix for parallel builds with MSVC 2015 and later
[Michael Davidsaver] rsrv: buffer for IP too small
[Andrew Johnson] Fix for lp: #1747091
[Andrew Johnson] Fix for LP: #1743076
[...truncated 1.59 MB...]
virtual void unlisten()
2 warnings generated.
make[4]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/modules/pvaClient/src/O.darwin-x86'>
fcntl(): Bad file descriptor
make[4]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/modules/pvaClient/src/O.darwin-x86'>
c++ -DUNIX -Ddarwin -O3 -g -Wall -arch x86_64 -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -c ../pvaClientNTMultiData.cpp
In file included from ../pvaClientNTMultiData.cpp:16:
In file included from ../pv/pvaClientMultiChannel.h:28:
../pv/pvaClient.h:1737:10: warning: 'epics::pvaClient::PvaClientMonitor::monitorConnect' hides overloaded virtual function [-Woverloaded-virtual]
void monitorConnect(
../pv/pvaClient.h:1604:18: note: hidden overloaded virtual function 'epics::pvaClient::PvaClientMonitorRequester::monitorConnect' declared here: type mismatch at 2nd parameter ('const PvaClientMonitorPtr &' (aka 'const shared_ptr<epics::pvaClient::PvaClientMonitor> &') vs 'const epics::pvData::MonitorPtr &' (aka 'const shared_ptr<epics::pvAccess::Monitor> &'))
virtual void monitorConnect(epics::pvData::Status const & status,
../pv/pvaClient.h:1741:10: warning: 'epics::pvaClient::PvaClientMonitor::unlisten' hides overloaded virtual function [-Woverloaded-virtual]
void unlisten(epics::pvData::MonitorPtr const & monitor);
../pv/pvaClient.h:1617:18: note: hidden overloaded virtual function 'epics::pvaClient::PvaClientMonitorRequester::unlisten' declared here: different number of parameters (0 vs 1)
c++ -DUNIX -Ddarwin -O3 -g -Wall -arch x86_64 -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -c ../pvaClientNTMultiMonitor.cpp
In file included from ../pvaClientNTMultiMonitor.cpp:19:
make[4]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/modules/pva2pva/pdbApp/O.darwin-x86'>
c++ -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/""> -DUNIX -Ddarwin -O3 -g -Wall -arch x86_64 -fno-common -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -c ../softMain.cpp
make[4]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/modules/pva2pva/pdbApp/O.darwin-x86'>
c++ -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/""> -DUNIX -Ddarwin -O3 -g -Wall -arch x86_64 -fno-common -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -c softIocPVA_registerRecordDeviceDriver.cpp
c++ -DUNIX -Ddarwin -O3 -g -Wall -arch x86_64 -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -c ../pvaClientRPC.cpp
In file included from ../pvaClientRPC.cpp:18:
c++ -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/""> -DUNIX -Ddarwin -O3 -g -Wall -arch x86_64 -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -c ../pdbgroup.cpp
c++ -o libpvaClient.4.7.1.dylib -dynamiclib -flat_namespace -undefined suppress -install_name <https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/lib/darwin-x86/libpvaClient.4.7.1.dylib> -compatibility_version 4.7.1 -current_version 4.7.1 -L<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/lib/darwin-x86> -arch x86_64 pvaClient.o pvaClientPutData.o pvaClientGetData.o pvaClientMonitorData.o pvaClientChannel.o pvaClientProcess.o pvaClientGet.o pvaClientPut.o pvaClientMonitor.o pvaClientPutGet.o pvaClientMultiChannel.o pvaClientMultiGetDouble.o pvaClientMultiPutDouble.o pvaClientMultiMonitorDouble.o pvaClientNTMultiPut.o pvaClientNTMultiData.o pvaClientNTMultiGet.o pvaClientNTMultiMonitor.o pvaClientRPC.o -lnt -lpvAccessIOC -lpvAccessCA -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom -lreadline -lm
ln -s libpvaClient.4.7.1.dylib <https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/lib/darwin-x86/libpvaClient.dylib>
/usr/bin/ar -rc libpvaClient.a pvaClient.o pvaClientPutData.o pvaClientGetData.o pvaClientMonitorData.o pvaClientChannel.o pvaClientProcess.o pvaClientGet.o pvaClientPut.o pvaClientMonitor.o pvaClientPutGet.o pvaClientMultiChannel.o pvaClientMultiGetDouble.o pvaClientMultiPutDouble.o pvaClientMultiMonitorDouble.o pvaClientNTMultiPut.o pvaClientNTMultiData.o pvaClientNTMultiGet.o pvaClientNTMultiMonitor.o pvaClientRPC.o
/usr/bin/ranlib libpvaClient.a
c++ -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/""> -DUNIX -Ddarwin -O3 -g -Wall -arch x86_64 -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -c ../configparse.cpp
c++ -o libqsrv.1.0.dylib -dynamiclib -flat_namespace -undefined suppress -install_name <https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/lib/darwin-x86/libqsrv.1.0.dylib> -compatibility_version 1.0 -current_version 1.0 -L<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/lib/darwin-x86> -arch x86_64 pvif.o qsrv.o pdb.o pdbsingle.o demo.o imagedemo.o pdbgroup.o configparse.o -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom -lreadline -lm
/usr/bin/ar -rc libqsrv.a pvif.o qsrv.o pdb.o pdbsingle.o demo.o imagedemo.o pdbgroup.o configparse.o
/usr/bin/ranlib libqsrv.a
ln -s libqsrv.1.0.dylib <https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/lib/darwin-x86/libqsrv.dylib>
c++ -o softIocPVA -L<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/lib/darwin-x86> -arch x86_64 softMain.o softIocPVA_registerRecordDeviceDriver.o -lqsrv -lpvAccessIOC -lpvAccessCA -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
/Users/jenkins/bin/make -C ./testApp install.darwin-x86
make[3]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/modules/pva2pva/testApp'>
perl -CSD <https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/bin/darwin-x86/makeMakefile.pl> O.darwin-x86 ../..
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/modules/pva2pva/testApp'>
perl -CSD <https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/bin/darwin-x86/makeMakefile.pl> O.ios-arm ../..
mkdir -p O.Common
/Users/jenkins/bin/make -C O.darwin-x86 -f ../Makefile TOP=../.. \
T_A=darwin-x86 install
make[4]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/modules/pva2pva/testApp/O.darwin-x86'>
perl -CSD <https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/bin/darwin-x86/mkmf.pl> -m check_consist.d -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> check_consist.o ../check_consist.cpp
make[4]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/modules/pva2pva/testApp/O.darwin-x86'>
perl -CSD <https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/bin/darwin-x86/mkmf.pl> -m testgroupconfig.d -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> testgroupconfig.o ../testgroupconfig.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/bin/darwin-x86/mkmf.pl> -m testpvif.d -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> testpvif.o ../testpvif.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/bin/darwin-x86/mkmf.pl> -m testweak.d -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> testweak.o ../testweak.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/bin/darwin-x86/mkmf.pl> -m utilitiesx.d -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> utilitiesx.o ../utilitiesx.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/bin/darwin-x86/mkmf.pl> -m testpdb.d -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> testpdb.o ../testpdb.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/bin/darwin-x86/mkmf.pl> -m testtest.d -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> testtest.o ../testtest.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/bin/darwin-x86/dbdExpand.pl> -I. -I.. -I../O.Common -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/dbd> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/dbd> -o p2pTestIoc.dbd base.dbd
perl -CSD <https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/bin/darwin-x86/registerRecordDeviceDriver.pl> -I. -I.. -I../O.Common -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/dbd> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/dbd> -o p2pTestIoc_registerRecordDeviceDriver.cpp ../O.Common/p2pTestIoc.dbd p2pTestIoc_registerRecordDeviceDriver <https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/>
perl -CSD <https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/bin/darwin-x86/mkmf.pl> -m p2pTestIoc_registerRecordDeviceDriver.d -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> p2pTestIoc_registerRecordDeviceDriver.o p2pTestIoc_registerRecordDeviceDriver.cpp
c++ -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Ddarwin -O3 -g -Wall -arch x86_64 -fno-common -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -c ../check_consist.cpp
c++ -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Ddarwin -O3 -g -Wall -arch x86_64 -fno-common -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -c ../testweak.cpp
c++ -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Ddarwin -O3 -g -Wall -arch x86_64 -fno-common -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -c p2pTestIoc_registerRecordDeviceDriver.cpp
c++ -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Ddarwin -O3 -g -Wall -arch x86_64 -fno-common -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -c ../testtest.cpp
c++ -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Ddarwin -O3 -g -Wall -arch x86_64 -fno-common -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -c ../testgroupconfig.cpp
c++ -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Ddarwin -O3 -g -Wall -arch x86_64 -fno-common -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -c ../testpvif.cpp
c++ -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Ddarwin -O3 -g -Wall -arch x86_64 -fno-common -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -c ../utilitiesx.cpp
c++ -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Ddarwin -O3 -g -Wall -arch x86_64 -fno-common -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/compiler/clang> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include/os/Darwin> -I<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/include> -c ../testpdb.cpp
c++ -o check_consist -L<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/lib/darwin-x86> -arch x86_64 check_consist.o utilitiesx.o -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
c++ -o testweak -L<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/lib/darwin-x86> -arch x86_64 testweak.o utilitiesx.o -lCom -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
c++ -o testtest -L<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/lib/darwin-x86> -arch x86_64 testtest.o utilitiesx.o -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
c++ -o testpvif -L<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/lib/darwin-x86> -arch x86_64 testpvif.o p2pTestIoc_registerRecordDeviceDriver.o utilitiesx.o -lqsrv -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
c++ -o testpdb -L<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/lib/darwin-x86> -arch x86_64 testpdb.o p2pTestIoc_registerRecordDeviceDriver.o utilitiesx.o -lqsrv -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
perl -CSD <https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/bin/darwin-x86/makeTestfile.pl> testweak.t testweak
perl -CSD <https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/bin/darwin-x86/makeTestfile.pl> testtest.t testtest
c++ -o testgroupconfig -L<https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/lib/darwin-x86> -arch x86_64 testgroupconfig.o utilitiesx.o -lqsrv -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
perl -CSD <https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/bin/darwin-x86/makeTestfile.pl> testpvif.t testpvif
perl -CSD <https://jenkins.aps.anl.gov/job/epics-master/OS=mac/ws/bin/darwin-x86/makeTestfile.pl> testpdb.t testpdb
/Users/jenkins/bin/make -C ./iocBoot install.darwin-x86
/Users/jenkins/bin/make -C ./iocwfdemo install.darwin-x86
/Users/jenkins/bin/make -C ./ioccircle2 install.darwin-x86
/Users/jenkins/bin/make -C ./ioccircle install.darwin-x86
/Users/jenkins/bin/make -C ./iocimagedemo install.darwin-x86
make[4]: Nothing to be done for 'install.darwin-x86'.
configure/RULES_DIRS:84: recipe for target 'modules.install.darwin-x86' failed
make: *** [modules.install.darwin-x86] Error 2
Build step 'Execute shell' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: **/O.*/*.tap
Did not find any matching files.
- Jenkins build is unstable: epics-master » mac #43 APS Jenkins
- Jenkins build became unstable: epics-master » mac #41 APS Jenkins
Build failed in Jenkins: epics-master » linux64 #42 APS Jenkins
Build failed in Jenkins: epics-master-windows » STATIC,win64 #32 APS Jenkins
<2018>
2025
2026
<2018>
2025
2026
