Freddie,
Do you by lucky chance have a recipe for finding where #include<>s are needed
before a link error is observed? I've just had one round of the brute force
method of commenting out all #include<> in header files, then adding #include<>s
to the source files until things compile again.
There must be a better way...
Michael
On 02/06/2018 03:43 PM, [email protected] wrote:
> Hi Mark,
> Do the enclosed changes fix it?
> Regards,
> Freddie
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf Of Mark Rivers
> Sent: 06 February 2018 22:47
> To: 'Michael Davidsaver'
> Cc: [email protected]
> Subject: RE: Build error for windows-x64-debug on VS2010
> Hi Michael,
> That fixed that error. I then got the same error with channel.cpp, so I did the same fix in that file.
> That then leads to this error, which I don't know how to fix:
> make[1]: Entering directory 'H:/epics-devel/base-7.0.1/modules/pva2pva/pdbApp'
> make -C O.windows-x64-debug -f ../Makefile TOP=../.. \
> T_A=windows-x64-debug install
> make[2]: Entering directory 'H:/epics-devel/base-7.0.1/modules/pva2pva/pdbApp/O.windows-x64-debug'
> link -nologo -subsystem:windows -dll -debug -incremental:no -fixed:no -MACHINE:X64 -out:qsrv.dll -implib:qsrv.lib pvif.obj qsrv.obj pdb.obj pdbsingle.obj demo.obj image
> demo.obj pdbgroup.obj configparse.obj H:/epics-devel/base-7.0.1/lib/windows-x64-debug/pvAccess.lib H:/epics-devel/base-7.0.1/lib/windows-x64-debug/pvData.lib H:/epics-devel/
> base-7.0.1/lib/windows-x64-debug/dbRecStd.lib H:/epics-devel/base-7.0.1/lib/windows-x64-debug/dbCore.lib H:/epics-devel/base-7.0.1/lib/windows-x64-debug/ca.lib H:/epics-devel/ba se-7.0.1/lib/windows-x64-debug/Com.lib
> pvAccess.lib(pvAccess.dll) : error LNK2005: "public: virtual __cdecl epics::pvAccess::ChannelFind::~ChannelFind(void)" (??1ChannelFind@pvAccess@epics@@UEAA@XZ) already defined in qsrv.obj
> pvAccess.lib(pvAccess.dll) : error LNK2005: "public: __cdecl epics::pvAccess::ChannelFind::ChannelFind(void)" (??0ChannelFind@pvAccess@epics@@QEAA@XZ) already defined in qsrv.obj
> Creating library qsrv.lib and object qsrv.exp qsrv.dll : fatal error LNK1169: one or more multiply defined symbols found
> H:/epics-devel/base-7.0.1/configure/RULES_BUILD:288: recipe for target 'qsrv.dll' failed
> make[2]: *** [qsrv.dll] Error 1169
> make[2]: Leaving directory 'H:/epics-devel/base-7.0.1/modules/pva2pva/pdbApp/O.windows-x64-debug'
> H:/epics-devel/base-7.0.1/configure/RULES_ARCHS:58: recipe for target 'install.windows-x64-debug' failed
> make[1]: *** [install.windows-x64-debug] Error 2
> make[1]: Leaving directory 'H:/epics-devel/base-7.0.1/modules/pva2pva/pdbApp'
> H:/epics-devel/base-7.0.1/configure/RULES_DIRS:84: recipe for target 'pdbApp.install' failed
> make: *** [pdbApp.install] Error 2
>> From: Michael Davidsaver [mailto:[email protected]]
>> Sent: Tuesday, February 06, 2018 4:28 PM
>> To: Mark Rivers <[email protected]>
>> Subject: Re: Build error for windows-x64-debug on VS2010
>> On 02/06/2018 01:25 PM, Mark Rivers wrote:
>>> I am getting an error building pva2pva for the windows-x64-debug
>>> architecture on
>> VS2010. I don't think this is an error I have previously reported. I
>> don't know how to fix it.
>>> link -nologo -debug -incremental:no -fixed:no -MACHINE:X64
>> out:p2p.exe gwmain.obj server.obj chancache.obj moncache.obj
>> channel.obj H:/epics-
>> devel/base-7.0
>>> .1/lib/windows-x64-debug/pvAccessIOC.lib
>> debug/pvAccess.lib
>> devel/b
>>> ase-7.0.1/lib/windows-x64-debug/Com.lib
>>> Com.lib(Com.dll) : error LNK2005: "public: __cdecl
>> epicsTimerNotify::epicsTimerNotify(void)"
>> (??0epicsTimerNotify@@QEAA@XZ) already defined in server.obj
>>> Creating library p2p.lib and object p2p.exp
>>> p2p.exe : fatal error LNK1169: one or more multiply defined symbols
>>> found
>> Gosh Mark, you sure find some good issues.
>> Let's assume this is an dllimport vs. export bug. Can you add the
>> following to p2pApp/server.cpp above the epicsExportSharedSymbols and
>> see if the situation changes at all?
>>> #include <epicsTimer.h> // add this line #define
- RE: Build error for windows-x64-debug on VS2010 freddie.akeroyd
- Build error for windows-x64-debug on VS2010 Mark Rivers
- Re: Build error for windows-x64-debug on VS2010 Michael Davidsaver
- RE: Build error for windows-x64-debug on VS2010 Mark Rivers
<2018>
2025
2026
<2018>
2025
2026
