The logic I am implementing now is:
If the string looks like a plain double (epicsParseDouble() succeeds and
units[0]=='\0') and event >= 0.0 and event < 256.0 treat it as a numeric
event: Round down to integer. Event number == 0 is no event.
Numeric events can be used with post_event() which is not tagged
"deprecated" any more.
At the moment, I have three cases of "no event at all":
* NULL No event name
* "" Empty event name
* [0.0 - 1.0[ Numeric event number 0
In particular, "2", "0x02", " 2.000000", "2.99999 " and " 200e-2 "
are the same event now.
"0", "0.00000", "0.99999", "-0" are no event.
"-2", "-0.00001", "256", "0x100", "256 ", " 256" are different named events.
I consider ignoring leading and trailing blanks, making "X Y", " X Y",
and "X Y " the same and making " " no event.
What do you think?
Dirk
On 08.02.2018 17:48, Andrew Johnson wrote:
Hi Dirk,
On 02/08/2018 07:23 AM, Dirk Zimoch wrote:
Attached is a patch file for dbScan.c which should fix the problem and
restore backward compatibility.
I have created (and quickly tested) it with EPICS 7 but I guess it
should work with 3.16 as well.
Please work against the 3.15 branch, since that was where we introduced
your named events work. We will merge it up into the later branches from
there.
The hack is to treat "x.000000" and "x" as the same event name if x is
an integer between 0 and 255. ("0" and "0.000000" are no event at all
now just like "").
I don't like the string comparisons since they would silently break if
the number of decimal digits generated by the double → string conversion
gets changed.
Better to parse the string properly into a double — look at the
epicsParseDouble() routine declared in epicsStdlib.h and documented at
https://epics.anl.gov/base/R3-15/5-docs/AppDevGuide/libComOSIlibraries.html#x21-84700020.13
— then either round or truncate the fractional part.
- Andrew
- Re: Scanning on event number fails with EPICS 3.16 Ralph Lange
- Re: Scanning on event number fails with EPICS 3.16 Johnson, Andrew N.
- Re: Scanning on event number fails with EPICS 3.16 Andrew Johnson
Re: Scanning on event number fails with EPICS 3.16 Dirk Zimoch
<2018>
2025
2026
<2018>
2025
2026
